coq-club - Re: [Coq-Club] Command line flags for warnings
  • From: Christian Doczkal <christian.doczkal AT ens-lyon.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Command line flags for warnings
  • Date: Wed, 8 Nov 2017 11:31:57 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=christian.doczkal AT ens-lyon.fr; spf=Neutral smtp.mailfrom=christian.doczkal AT ens-lyon.fr; spf=None smtp.helo=postmaster AT labbe.ens-lyon.fr
  • Ironport-phdr: 9a23:ZIh7zBdz2SckmcTu8ZS+0NnBlGMj4u6mDksu8pMizoh2WeGdxc29ZB7h7PlgxGXEQZ/co6odzbGJ4+a9ASQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpW1aJhKqPg1sY+/xB4T6jsKt1un09YeATR9PgW+WYalzNwm3pAOZms4dk4hrLu5lwRvTo2BUeu1Qg29vLkCQlhLU68GruZpy9CIWteh3pJ0IarnzY6ltFe8QNz8hKW1gvMA=
Hello,
That was indeed very helpful. Maybe the manual could be improved to more
clearly state the connection between the printed messages and the
command-line switches.
Somewhat related, there are other warnings (e.g., "Warning: Noting to
inject.") that predate the current warning system and seem to be
unaffected by any warning switches. Is there a way to turn the
aforementioned waring off or into an error?
Best,
Christian
Is there also a way for turning "Warning: Nothing to Inject" into a
On 11/05/2017 12:16 PM, Théo Zimmermann wrote:
> Hi,
> Section 6.9.3
> (https://coq.inria.fr/distrib/current/refman/vernacular.html#SetWarnings)
> also says "Adding - in front of a warning or category disables it, adding +
> makes it an error. It is possible to use the special categories all and
> default, the latter containing the warnings enabled by default."
> The warnings names and categories are displayed whenever you see such a
> warning (I ignore if there is a command to display all warning names or
> categories).
> E.g. if you type "Variable A : Prop." in an empty buffer, you will see:
> "A is declared as a local axiom [local-declaration,scope]"
> The warning name is local-declaration and the category is scope.
> Thus if you relaunch CoqIDE (or coqtop through Proof-General) with option
> -w "-local-declaration", you won't see any warning for the same buffer.
> And if you use option -w "+local-declaration", you will see an error
> instead.
> Théo
> Le sam. 4 nov. 2017 à 23:27, Erkki Luuk
> <erkkil AT gmail.com
> <mailto:erkkil AT gmail.com>>
> a écrit :
> Hi
> Where do I find the command line flags for warning names and
> categories? The manual just says:
> -w (all|none|w1,…,wn)
> Configure the display of warnings. This option expects all, none or a
> comma-separated list of warning names or categories (see Section 6.9.3).
> https://coq.inria.fr/distrib/current/refman/commands.html#hevea_default978
> Erkki
