- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Obtaining the term matched by "context"
- Date: Mon, 13 Nov 2017 17:58:08 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=pierre.courtieu AT gmail.com; spf=Pass smtp.mailfrom=pierre.courtieu AT gmail.com; spf=None smtp.helo=postmaster AT mail-oi0-f50.google.com
- Ironport-phdr: 9a23:pGsD9xVswhdlhYuQf5b3mI30KIbV8LGtZVwlr6E/grcLSJyIuqrYZR2At8tkgFKBZ4jH8fUM07OQ6P+wHzFYqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aMlzFOAF0PuX4HJLJx4Tyjrjqus6bXwIdrz2kKZh2MR/++Q7Wr4wdhZZoAqc30BrA5HVSLbd432RtcGqSkgzm64+b+4N57yVdprp1789NS7/3Oa8/UKZEDTk7G28w7czv8xLESF3ctTMnTmwKn08QUED+5xbgU8K063Oiuw==
Hi,
I think you are asking for the "as" pattern inside contexts ltac. I
don't think it
is implemented but would be a valid feature wish imho.
repeat match goal with
| _: context [(1 + ?x) as foo] |- _ => change foo with (S x) in *
Regarding factorization of tactics you can do it like you would in a
standard functional programming language, with a let binding:
repeat
let oneplusx :=
(match goal with
| H: context [1 + ?x] |- _ => constr:(1 + x)
| |- context [1 + ?x] => constr:(1 + x)
end) in
match oneplusx with
| context [1 + ?x] => change oneplusx with (S x) in *
end.
Best regards
P.
2017-11-13 16:10 GMT+01:00 Samuel Gruetter
<gruetter AT mit.edu>:
> Dear coq-club,
> I have two questions about Ltac's match with "context".
> I often write code like this:
> Goal forall a b c, a + (1 + b) = c -> (1 + a) + b = c.
> intros.
> | _: context [1 + ?x] |- _ => change (1 + x) with (S x) in *
> | |- context [1 + ?x] => change (1 + x) with (S x) in *
> end.
> Abort.
> There are two things I'd like to improve, but don't know how to do it:
> 1) I write the same line twice, once for matching in the hypotheses, once
> for matching in the goal. Can this be unified?
> 2) On the right-hand side of "=>", I have to repeat the term (1 + x), just
> without the question marks. This is bad because it's code duplication,
> and it gets even worse if the term contains implicit arguments: It
> happens often to me that the implicit arguments inferred on the right-
> hand side of "=>" don't match the original ones, so that "change" does
> nothing. Therefore, I wonder if there's a way to refer to the
> "term matched inside context"?
> (I'm aware that I can write "context C[1 + ?x]", but C gives me the
> context *around* the term, i.e. everything *except* what I want)
> Thanks in advance,
> Sam
- [Coq-Club] Obtaining the term matched by "context", Samuel Gruetter, 11/13/2017
- Re: [Coq-Club] Obtaining the term matched by "context", Pierre Courtieu, 11/13/2017
- Re: [Coq-Club] Obtaining the term matched by "context", Samuel Gruetter, 11/14/2017
