- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Obtaining the term matched by "context"
- Date: Tue, 14 Nov 2017 14:05:21 +0000
- Accept-language: en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gruetter AT mit.edu; spf=Pass smtp.mailfrom=gruetter AT mit.edu; spf=None smtp.helo=postmaster AT dmz-mailsec-scanner-4.mit.edu
- Ironport-phdr: 9a23:o2EfXxGW4etpAMb3SEINkp1GYnF86YWxBRYc798ds5kLTJ76oMuwAkXT6L1XgUPTWs2DsrQf1LqQ7viocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TXhpQIVT1/0MhMwLeDoEKbTid623qa84debNw5PnX+2Za54BBSwtwTY8McM19hMMKE0nyDAp2ZFf6x5335lOU6ehV6o6d2t8YJ//j54vvM9scNMTPOpLOwDUbVEAWF+YCgO78rxuEybQA==
On Mon, 2017-11-13 at 17:58 +0100, Pierre Courtieu wrote:
> Hi,
> I think you are asking for the "as" pattern inside contexts ltac. I
> don't think it
> is implemented but would be a valid feature wish imho.
> repeat match goal with
> | _: context [(1 + ?x) as foo] |- _ => change foo with (S x) in *
Yes, that's exactly what I meant.
Actually, this might also be useful outside "context", e.g.
| H: myFunc ((1 + ?x) as foo) |- _ => apply (myLemma foo) in H
end
> Regarding factorization of tactics you can do it like you would in a
> standard functional programming language, with a let binding:
> repeat
> let oneplusx :=
> (match goal with
> | H: context [1 + ?x] |- _ => constr:(1 + x)
> | |- context [1 + ?x] => constr:(1 + x)
> end) in
> match oneplusx with
> | context [1 + ?x] => change oneplusx with (S x) in *
> end.
I see... So let's apply this to a case with 2 actual branches:
I start with this:
Require Import Coq.Arith.PeanoNat.
Goal forall a b c, (a + 1) + (1 + b) = c -> (1 + a) + (b + 1) = c.
intros.
| _: context [1 + ?x] |- _ => change (1 + x) with (S x) in *
| |- context [1 + ?x] => change (1 + x) with (S x) in *
| _: context [?x + 1] |- _ => rewrite (Nat.add_comm x 1) in *
| |- context [?x + 1] => rewrite (Nat.add_comm x 1) in *
end.
Abort.
and to avoid the duplication, I turn it into this:
intros.
repeat
let matched :=
(match goal with
| _: context [1 + ?x] |- _ => constr:(1 + x)
| _: context [?x + 1] |- _ => constr:(x + 1)
| |- context [?x + 1] => constr:(x + 1)
end)
in match matched with
| 1 + ?x => change matched with (S x) in *
| ?x + 1 => rewrite (Nat.add_comm x 1) in *
end.
Abort.
This works fine in this simple example, but it won't work any more when the
choice of which branch to take depends on whether the tactic on the right-
hand side of "=>" succeeds.
So I'd have to change it to something like the following I guess?
intros.
repeat first
[ let oneplusx :=
(match goal with
end)
in match oneplusx with
| 1 + ?x => change oneplusx with (S x) in *
end
| let xplusone :=
(match goal with
end)
in match xplusone with
end
Abort.
This is not very satisfactory to me because it's too complex.
What I'd really like to write is this:
intros.
end.
Abort.
Are there any good reasons for not supporting this?
> Best regards
> P.
> 2017-11-13 16:10 GMT+01:00 Samuel Gruetter
> <gruetter AT mit.edu>:
> > Dear coq-club,
> > I have two questions about Ltac's match with "context".
> > I often write code like this:
> > Goal forall a b c, a + (1 + b) = c -> (1 + a) + b = c.
> > intros.
> > end.
> > Abort.
> > There are two things I'd like to improve, but don't know how to do it:
> > 1) I write the same line twice, once for matching in the hypotheses, once
> > for matching in the goal. Can this be unified?
> > 2) On the right-hand side of "=>", I have to repeat the term (1 + x),
> > just
> > without the question marks. This is bad because it's code duplication,
> > and it gets even worse if the term contains implicit arguments: It
> > happens often to me that the implicit arguments inferred on the right-
> > hand side of "=>" don't match the original ones, so that "change" does
> > nothing. Therefore, I wonder if there's a way to refer to the
> > "term matched inside context"?
> > (I'm aware that I can write "context C[1 + ?x]", but C gives me the
> > context *around* the term, i.e. everything *except* what I want)
> > Thanks in advance,
> > Sam
- [Coq-Club] Obtaining the term matched by "context", Samuel Gruetter, 11/13/2017
- Re: [Coq-Club] Obtaining the term matched by "context", Pierre Courtieu, 11/13/2017
- Re: [Coq-Club] Obtaining the term matched by "context", Samuel Gruetter, 11/14/2017
