coq-club - Re: [Coq-Club] Looking up definitions from inside an ml plugin
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Looking up definitions from inside an ml plugin
  • Date: Thu, 16 Nov 2017 10:31:36 -0800
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=tringer AT cs.washington.edu; spf=None smtp.mailfrom=tringer AT cs.washington.edu; spf=None smtp.helo=postmaster AT mail-vk0-f41.google.com
  • Ironport-phdr: 9a23:vQprnxMQG8I1xXhEGmMl6mtUPXoX/o7sNwtQ0KIMzox0K/r6rarrMEGX3/hxlliBBdydsK0UzbeO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6a8TWO6msZHQy6Pg5oLMz0HJTThoK5zbOc4ZrWNjlBgDu0KYlzKhq7t02FqtMXh4RvMI460V3Wq2BIeuJZ2WRuY1+fgkCvtY+L4Jd//nEI6Loa/MlaXPCicg==
I should note that, if you have access to the term itself, unquestionably the best way to do this is to not make it a string to begin with. In traversing the AST for the term:
forall x, x=Const 4
When traversing the product Prod (n, t, b), and then recursing in and evaluating t, you should eventually get a term Ind((i, _), _). Similarly, when recursing into the body b, you should find that it is a constructor Construct (((i, _), _, _). So you can pass that in directly to look up the inductive type.
If the user is providing you an argument, then rather than making that argument a string, you can make that argument a term. You'll have to intern that term to then traverse the AST in the current environment.
The only time I had to ever go to strings was when I was working around limitations of my tool, so it's understandable that it can happen sometimes, but often you're able to use a much better format and never deal with strings at all.
On Thu, Nov 16, 2017 at 10:17 AM, Talia Ringer <tringer AT cs.washington.edu> wrote:
It is an i of type mutual_inductive, which is an alias for MutInd.t. You can find MutInd.t in names.mli.
You can get that from the AST in this way:
| Construct (((i, _), _, _) ->
   let mutind_body = lookup_mind i env in ...
| Ind ((i, _), _) ->
To actually construct a name of an inductive type from a string is a little more complicated. I do it in this plugin in the function inductive_of_elim. It looks roughly like this:
let ind_label = Label.of_id (Id.of_string_soft ind_label_string) in
let ind_name = MutInd.make1 (KerName.make modpath dirpath ind_label) in
let body = lookup_mind ind_name env in ...
Where modpath and dirpath make the name fully-qualified.
I'm not sure why you have a string, but if you have a constant somewhere and just want to modify it a bit and then use that string to lookup_mind, your job is a little easier, because you can repr the fully qualified name:
let kn = Constant.canonical c in
let (modpath, dirpath, label) = KerName.repr kn in ...
Anyways, I suggest looking at names.mli, or whatever the equivalent is in the newest Coq plugin API.
