- To: Talia Ringer <tringer AT cs.washington.edu>
- Cc: Coq-Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Looking up definitions from inside an ml plugin
- Date: Sat, 18 Nov 2017 23:09:24 +0000
- Accept-language: en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=kendroe AT hotmail.com; spf=Pass smtp.mailfrom=kendroe AT hotmail.com; spf=Pass smtp.helo=postmaster AT NAM02-CY1-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23:XNKfPR+nqSixRf9uRHKM819IXTAuvvDOBiVQ1KB+2uMcTK2v8tzYMVDF4r011RmSAtWdtqoMotGVmp6jcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS47WLmffqXyq7DMUBg63dU8sfry0ScbuiJGL3uSz8tXpYgNHiSD1Na9oLRO5oB/5vdJQnoJ5Kqc3xQfOpD1Fd/kAlk1yIlfGvBv64Mqs/NZZ9CkY7/Es8cJaVqjSf6MkSLVZCHItNGVjt56jjgXKUQbavihUaW4RiBcdRlGdtBw=
- Spamdiagnosticmetadata: NSPM
- Spamdiagnosticoutput: 1:99
Things seem to be getting closer. Here is the code that I currently have:
let rec sl h r = match r with
| [x] -> (h,x)
| [] -> (h,"")
| (f::r) -> sl (List.append h [f]) r
in
let (path,name) = sl [] (String.split_on_char '.' root) in
let dirpath = DirPath.make (List.map Id.of_string path) in
let modpath = ModPath.MPfile dirpath in
let (evm, env) = Lemmas.get_current_context() in
let d = Environ.lookup_mind (MutInd.make2 modpath (Names.Label.make name)) env in
Given that "root" has the string "C_Top.x",
I am trying to find the definition. This code does not seem to work. What do I need to change to make the code work?
Note that I have two separate questions on the mailing list. The first is to find a definition given a string with a path. The second question (which is separate) is how to traverse the environment.
- Ken
Sent: Friday, November 17, 2017 11:33 AM
To: Kenneth Roe
Cc: Coq-Club
To: Kenneth Roe
Cc: Coq-Club
Again, my high-level advice is not to get a string there if possible. Do you absolutely need that to be a string? If it's tactic input, it can refer directly to the term, and then you do not need a string.
If you must use a string (which can happen), you should look at the interfaces in names.mli. You probably want something like:let modpath = ModPath.MPfile dirpath in
lookup_mind (MutInd.make2 modpath label) env
DirPath.make (List.map Id.of_string ["Logic"; "Init"; "Coq"])
But what is confusing to me is why you have a non-hardcoded (presumably user-provided) string with none of this information. If the user were providing you a constant instead, then you would be able to recover its modpath, dirpath, and label using
repr. I've only ever had to construct a DirPath to refer to a specific hard-coded term in the Coq code, like the identity function.
It would probably help to see your code, but if you really need a string then you're going to want to at the interfaces for ModPath, DirPath, Label, MutInd and so on.
On Fri, Nov 17, 2017 at 5:49 AM, Kenneth Roe
<kendroe AT hotmail.com> wrote:
Actually, the above only partially answers my question. I still need to know how to generate "modpath" and "dirpath". I'm starting with the string "C_Top.x" and I presume that "C_Top" is the path for the top level environment.
- Ken
Sent: Thursday, November 16, 2017 11:31 AM
To: Talia Ringer
Subject: Re: [Coq-Club] Looking up definitions from inside an ml pluginThanks. By the way, you might want to take a look at the repository at https://github.com/kendroe/CoqRewriter. This is the rewriting plugin that I'm creating. The Coq interface is based on your printAST code. I recently converted this code to Coq 8.7. You can take the plugin.ml4 file and strip out all the stuff related to the rewriter. I kept the printAST function intact.
- Ken
From: coq-club-request AT inria.fr <coq-club-request AT inria.fr> on behalf of Talia Ringer <tringer AT cs.washington.edu>
Sent: Thursday, November 16, 2017 10:31 AM
To: coq-club AT inria.fr
Subject: Re: [Coq-Club] Looking up definitions from inside an ml pluginI should note that, if you have access to the term itself, unquestionably the best way to do this is to not make it a string to begin with. In traversing the AST for the term:
forall x, x=Const 4
When traversing the product Prod (n, t, b), and then recursing in and evaluating t, you should eventually get a term Ind((i, _), _). Similarly, when recursing into the body b, you should find that it is a constructor Construct (((i, _), _, _). So you can pass that in directly to look up the inductive type.
If the user is providing you an argument, then rather than making that argument a string, you can make that argument a term. You'll have to intern that term to then traverse the AST in the current environment.
The only time I had to ever go to strings was when I was working around limitations of my tool, so it's understandable that it can happen sometimes, but often you're able to use a much better format and never deal with strings at all.
On Thu, Nov 16, 2017 at 10:17 AM, Talia Ringer <tringer AT cs.washington.edu> wrote:
It is an i of type mutual_inductive, which is an alias for MutInd.t. You can find MutInd.t in names.mli.
You can get that from the AST in this way:
| Construct (((i, _), _, _) ->
let mutind_body = lookup_mind i env in ...
| Ind ((i, _), _) ->
To actually construct a name of an inductive type from a string is a little more complicated. I do it in this plugin in the function inductive_of_elim. It looks roughly like this:
let ind_label = Label.of_id (Id.of_string_soft ind_label_string) in
let ind_name = MutInd.make1 (KerName.make modpath dirpath ind_label) in
let body = lookup_mind ind_name env in ...
Where modpath and dirpath make the name fully-qualified.
I'm not sure why you have a string, but if you have a constant somewhere and just want to modify it a bit and then use that string to lookup_mind, your job is a little easier, because you can repr the fully qualified name:
let kn = Constant.canonical c in
let (modpath, dirpath, label) = KerName.repr kn in ...
Anyways, I suggest looking at names.mli, or whatever the equivalent is in the newest Coq plugin API.
- [Coq-Club] Looking up definitions from inside an ml plugin, Kenneth Roe, 11/16/2017
- Re: [Coq-Club] Looking up definitions from inside an ml plugin, Talia Ringer, 11/16/2017
- Message not available
- Re: [Coq-Club] Looking up definitions from inside an ml plugin, Kenneth Roe, 11/17/2017
- Re: [Coq-Club] Looking up definitions from inside an ml plugin, Talia Ringer, 11/17/2017
- Re: [Coq-Club] Looking up definitions from inside an ml plugin, Kenneth Roe, 11/19/2017
- Re: [Coq-Club] Looking up definitions from inside an ml plugin, Matthieu Sozeau, 11/19/2017
