coq-club - Re: [Coq-Club] How strong is this deferredFix axiom?
  • From: Joachim Breitner <mail AT joachim-breitner.de>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] How strong is this deferredFix axiom?
  • Date: Fri, 08 Dec 2017 10:50:19 -0500
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mail AT joachim-breitner.de; spf=Neutral smtp.mailfrom=mail AT joachim-breitner.de; spf=None smtp.helo=postmaster AT hermes.serverama.de
  • Ironport-phdr: 9a23:Fd5hkh+BFcmYcv9uRHKM819IXTAuvvDOBiVQ1KB+2+wcTK2v8tzYMVDF4r011RmSAtWdtqoMotGVmp6jcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS47TeVDInX2z8TNXXzy3dU8sfry0ScbuiJG80Pn38JnOaS1JgiC8aPV8NkaYtwLU4+sRiIBiK6N54AHEo2dOdv4ekWZhJFa7nRH17cex+dtp6SlRp/Qs7YhMXPOpLOwDUbVEAWF+YCgO78rxuEyGFFPX6w==
Dear Gaëtan,
please allow me to get back to this.
Am Mittwoch, den 06.12.2017, 21:56 +0100 schrieb Gaëtan Gilbert:
> It's equivalent to epsilon.
> Let A : Type. Consider the function
> λ x : A + bool => match x with inl a => inl a | inr b => inr (not b)
> It has a fixed point if and only if A is inhabited, but A + bool is
> always inhabited (eg by inl true).
> In the attached file I use this to prove epsilon from your axioms.
in your file you define
Lemma epsilon A (H : inhabited A) : A.
but that is not (as I first thought) the epsilon from
Coq.Logic.ClassicalEpsilon or Coq.Logic.Epsilon, which is
Definition epsilon (A : Type) (i:inhabited A) (P : A->Prop) : A
I see that your [epsilon] allows me to get a value out of an
[inhabited A], which is usually not allowed, but what are the
consequences of that? How does it related to the full Hilbert’s axiom?
Thanks,
Joachim
Joachim Breitner
http://www.joachim-breitner.de/
Attachment: signature.asc
Description: This is a digitally signed message part
