- From: Matěj Grabovský <matej.grabovsky AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Trouble with dependent induction
- Date: Tue, 19 Dec 2017 14:22:21 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=matej.grabovsky AT gmail.com; spf=Pass smtp.mailfrom=matej.grabovsky AT gmail.com; spf=None smtp.helo=postmaster AT mail-lf0-f42.google.com
- Ironport-phdr: 9a23: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
Thank you all for your helpful comments. I believe I now have a
slightly better insight into this pattern in Coq.
I really like Adam's idea. I am aware of CPDT, though I hadn't looked
at that specific chapter. It does seem useful at the moment.
On 17 December 2017 at 20:05, Matthieu Sozeau
<mattam AT mattam.org>
wrote:
> Hi Jesper,
> you could alternatively use the [depelim] tactic that's part
> of Equations which would avoid the use of an axiom in this case
> (as the index type is discriminable as fin_case above shows as well).
> Either way using induction/case analysis on the vector or index first.
> From Equations Require Import Equations DepElimDec.
> Lemma replace_fact1 {A n} (xs : Vector.t A n) i x : (Vector.replace xs i
> x)[@i] = x.
> Proof.
> induction xs.
> - depelim i.
> - depelim i.
> + reflexivity.
> + now cbn.
> Qed.
> Lemma replace_fact1' {A n} (xs : Vector.t A n) i x : (Vector.replace xs i
> x)[@i] = x.
> Proof.
> induction i.
> - depelim xs. simpl. reflexivity.
> - depelim xs. simpl. auto.
> Qed.
> Print Assumptions replace_fact1.
> Print Assumptions replace_fact1'.
> Best,
> -- Matthieu
> On Sun, Dec 17, 2017 at 2:42 PM Adam Chlipala
> <adamc AT csail.mit.edu>
> wrote:
>> I went about the proof in the other direction (induction on vector, case
>> analysis on index). My intention was for this sort of thing to be covered
>> well in CPDT (maybe in the section about how to avoid axioms), so I'll
>> appreciate any suggestions on how I might have missed the requisite ideas.
>> Lemma fin_case : forall {n} (i : Fin.t n),
>> match n return Fin.t n -> Prop with
>> | O => fun _ => False
>> | S _ => fun i => i = Fin.F1 \/ exists i', i = Fin.FS i'
>> end i.
>> Proof.
>> destruct i; eauto.
>> Qed.
>> Lemma replace_fact1 : forall A n (xs : Vector.t A n) i x, (Vector.replace
>> xs i x)[@i] = x.
>> Proof.
>> induction xs; intro i; destruct (fin_case i); firstorder (subst; simpl);
>> eauto.
>> Qed.
>> On 12/17/2017 07:37 AM, Jasper Hugunin wrote:
>> Hello Matěj,
>> The reason you are missing the induction hypothesis is you never performed
>> an induction (or a fixpoint).
>> You can get the induction hypothesis by starting off with something like
>> refine ((fix inner n (i : Fin.t n) (xs : Vector.t A n) := match i as i'
>> in Fin.t n' ...) n i xs)
>> However, when I tried that route, I got stuck at Qed with a message saying
>> the induction hypothesis was not used on a smaller term.
>> Here is a way to prove that lemma without axioms in pure Gallina:
>> Fixpoint replace_fact1 {A n} (xs : Vector.t A n) i x
>> : (Vector.replace xs i x)[@i] = x
>> := match i in Fin.t n'
>> return forall (xs : Vector.t A n'), (Vector.replace xs i x)[@i] = x
>> with
>> | Fin.F1 => fun xs => Vector.caseS' xs
>> (fun xs => (Vector.replace xs Fin.F1 x)[@Fin.F1] = x)
>> (fun a xs' => eq_refl : x = x)
>> | Fin.FS i' => fun xs => Vector.caseS' xs
>> (fun xs => (Vector.replace xs (Fin.FS i') x)[@Fin.FS i'] = x)
>> (fun a xs' => replace_fact1 xs' i' x
>> : (Vector.replace xs' i' x)[@i'] = x)
>> end xs.
>> I don't use Ltac, so I can't help translating the above into tactics,
>> but hopefully the above is useful in understanding what is going on behind
>> the scenes.
>> Perhaps just writing the outer fix+match (the fix is embedded in the
>> Fixpoint command)
>> as your refine would be enough to get started.
>> - Jasper Hugunin
>> On Sun, Dec 17, 2017 at 8:34 PM, Matěj Grabovský
>> wrote:
>>> Hello.
>>> I'm trying to prove the following, apparently simple statement about
>>> the Vector.replace function from the standard library (the full code
>>> is at http://lpaste.net/360859):
>>> forall {A n} (xs : Vector.t A n) i x, (Vector.replace xs i x)[@i] = x
>>> Although I can prove this just fine using Program, I'd also like to
>>> perform the proof without it, without assuming additional axioms.
>>> However, I can't quite wrap my head around what's going on with all
>>> the type dependencies.
>>> I can destruct the with an intricate matching trick, but I'm unable to
>>> proceed in the latter branch as I need more information for the proof
>>> to progress.
>>> What is the Coq canonical/recommended approach to dependent induction
>>> without on inductives indexed by types with decidable equality? Is
>>> there a general approach to this? If not, how would I go about this in
>>> the Vector case?
>>> Note that I'm not looking for alternatives to stdlib Vector or
>>> specialised libraries as of now. I'd very much like to understand the
>>> concept in vanilla Coq first.
>>> Best regards,
>>> Matěj
- Re: [Coq-Club] Trouble with dependent induction, (continued)
- Re: [Coq-Club] Trouble with dependent induction, Adam Chlipala, 12/17/2017
- [Coq-Club] Vector in Coq [Was: Re: Trouble with dependent induction], Emilio Jesús Gallego Arias, 12/17/2017
- Re: [Coq-Club] Vector in Coq [Was: Re: Trouble with dependent induction], Adam Chlipala, 12/17/2017
- Re: [Coq-Club] Vector in Coq [Was: Re: Trouble with dependent induction], Robby Findler, 12/17/2017
- Re: [Coq-Club] Vector in Coq [Was: Re: Trouble with dependent induction], Emilio Jesús Gallego Arias, 12/17/2017
- Re: [Coq-Club] Vector in Coq [Was: Re: Trouble with dependent induction], Xavier Leroy, 12/17/2017
- Re: [Coq-Club] Vector in Coq [Was: Re: Trouble with dependent induction], Emilio Jesús Gallego Arias, 12/20/2017
- Re: [Coq-Club] Vector in Coq [Was: Re: Trouble with dependent induction], Adam Chlipala, 12/18/2017
- Re: [Coq-Club] Trouble with dependent induction, Matthieu Sozeau, 12/17/2017
- Re: [Coq-Club] Trouble with dependent induction, Matěj Grabovský, 12/19/2017
