- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] [NEWBIE] Applying Nat.eq_dec
- Date: Fri, 5 Jan 2018 15:13:20 -0800
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=artagnon AT gmail.com; spf=Pass smtp.mailfrom=artagnon AT gmail.com; spf=None smtp.helo=postmaster AT mail-yw0-f178.google.com
- Ironport-phdr: 9a23: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
Thanks much!
I have a more general question about proving engineering facts about Maps. Stuff like the one I showed above, or even this other place where I got stuck:
Lemma mapElements_add : forall (n : nat) (m : registration),
M.elements (elt := registration) (M.add n m [| |]) = (n |-> m) :: nil.
Proof.
intros.
unfold M.elements; unfold M.Raw.elements.
- n: nat
- m: registration
- 1/1M.Raw.elements_aux nil (M.this (M.add n m [| |])) = (n |-> m) :: nil
... am I doing something wrong, because the Standard Library doesn't seem to have anything that I can use? Must I prove all these elementary properties of Maps before I proceed to use them in larger proofs?
Thanks.
Ram
On Fri, Jan 5, 2018 at 1:59 PM, Yao Li <liyao AT seas.upenn.edu> wrote:
In your first proof: your goal is falsehood, but you also have a contradiction in your hypothesis. The “contradiction” tactic should be able to solve the goal.Your second proof seems to be on the wrong track. I guess what you are trying to say is that [a] always equals to [a], but that is not what [trivialEq] is actually saying...A general lemma that may be useful to you is:Lemma eq_dec_refl_branch {A} : forall a (b c : A),(if Nat.eq_dec a a then b else c) = b.
Proof. intros. destruct (Nat.eq_dec a a); auto; contradiction. Qed.Best,YaoOn 5 Jan 2018, at 4:12 PM, Ramkumar Ramachandra <artagnon AT gmail.com> wrote:Now I have an additional Lemma which I'm not able to apply, due to "Cannot change D, it is used in conclusion".Lemma trivialEq : forall a : M.key, {a = a} + {a <> a} -> True.Proof.trivial.Qed.Lemma keyInMap : forall a b, M.find (elt := nat) a [a |-> b] = Some b.Proof.intros.unfold update. unfold fst. unfold snd.rewrite F.add_o.unfold Nat_as_OT.eq_dec.remember (Nat.eq_dec a a) as D.apply trivialEq in D.My hypothesis and goals window looks like this in the last step:
- a: M.key
- b: nat
- D: {a = a} + {a <> a}
- HeqD: D = Nat.eq_dec a a
- 1/1(if D then Some b else M.find (elt:=nat) a [ ]) = Some b
Why do I get the error? I have all the right types for unification.Thanks.RamOn Thu, Jan 4, 2018 at 6:47 PM, Ramkumar Ramachandra <artagnon AT gmail.com> wrote:Hi folks,I'm trying to use Coq to prove that M.find (referring to FMapAVL) finds an element that exists in the map. Here's my progress so far:Lemma keyInMap : forall a b, M.find (elt := nat) a [a |-> b] = Some b.Proof.intros.unfold update. unfold fst. unfold snd.rewrite F.add_o.unfold Nat_as_OT.eq_dec.remember (Nat.eq_dec a a) as D.induction D.reflexivity.rewrite F.empty_o.Qed.Somehow, I get stuck with this to prove:
- a: M.key
- b: nat
- b0: a <> a
- HeqD: right b0 = Nat.eq_dec a a
- 1/1None = Some b
Which is a falsehood, so I think I did the wrong thing by using "induction D". To eliminate one of the cases of the `if`, I will need to apply `Nat.eq_dec`, and I'm unable to apply it for some strange reason.Some pointers would be appreciated.Thanks.Ram
- [Coq-Club] [NEWBIE] Applying Nat.eq_dec, Ramkumar Ramachandra, 01/05/2018
- Re: [Coq-Club] [NEWBIE] Applying Nat.eq_dec, Ramkumar Ramachandra, 01/05/2018
- Re: [Coq-Club] [NEWBIE] Applying Nat.eq_dec, Yao Li, 01/05/2018
- Re: [Coq-Club] [NEWBIE] Applying Nat.eq_dec, Ramkumar Ramachandra, 01/06/2018
- Re: [Coq-Club] [NEWBIE] Applying Nat.eq_dec, Yao Li, 01/06/2018
- Re: [Coq-Club] [NEWBIE] Applying Nat.eq_dec, ikdc, 01/07/2018
