coq-club - Re: [Coq-Club] [NEWBIE] Applying Nat.eq_dec
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] [NEWBIE] Applying Nat.eq_dec
  • Date: Fri, 5 Jan 2018 20:33:15 -0500
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=liyao AT seas.upenn.edu; spf=Pass smtp.mailfrom=liyao AT seas.upenn.edu; spf=None smtp.helo=postmaster AT fox.seas.upenn.edu
  • Ironport-phdr: 9a23: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
I think FMapFacts contains something you need?
Best,
Yao
On 5 Jan 2018, at 6:13 PM, Ramkumar Ramachandra <artagnon AT gmail.com> wrote:
Thanks much!
I have a more general question about proving engineering facts about Maps. Stuff like the one I showed above, or even this other place where I got stuck:
Lemma mapElements_add : forall (n : nat) (m : registration),
M.elements (elt := registration) (M.add n m [| |]) = (n |-> m) :: nil.
Proof.
intros.
unfold M.elements; unfold M.Raw.elements.
  • n: nat
  • m: registration
  • 1/1M.Raw.elements_aux nil (M.this (M.add n m [| |])) = (n |-> m) :: nil
... am I doing something wrong, because the Standard Library doesn't seem to have anything that I can use? Must I prove all these elementary properties of Maps before I proceed to use them in larger proofs?
Thanks.
Ram
On Fri, Jan 5, 2018 at 1:59 PM, Yao Li <liyao AT seas.upenn.edu> wrote:
In your first proof: your goal is falsehood, but you also have a contradiction in your hypothesis. The “contradiction” tactic should be able to solve the goal.
Your second proof seems to be on the wrong track. I guess what you are trying to say is that [a] always equals to [a], but that is not what [trivialEq] is actually saying...
A general lemma that may be useful to you is:
Lemma eq_dec_refl_branch {A} : forall a (b c : A),
    (if Nat.eq_dec a a then b else c) = b.
Proof. intros. destruct (Nat.eq_dec a a); auto; contradiction. Qed.
Best,
Yao
On 5 Jan 2018, at 4:12 PM, Ramkumar Ramachandra <artagnon AT gmail.com> wrote:
Now I have an additional Lemma which I'm not able to apply, due to "Cannot change D, it is used in conclusion".
Lemma trivialEq : forall a : M.key, {a = a} + {a <> a} -> True.
Proof.
trivial.
Qed.
Lemma keyInMap : forall a b, M.find (elt := nat) a [a |-> b] = Some b.
Proof.
intros.
unfold update. unfold fst. unfold snd.
rewrite F.add_o.
unfold Nat_as_OT.eq_dec.
remember (Nat.eq_dec a a) as D.
apply trivialEq in D.
My hypothesis and goals window looks like this in the last step:
  • a: M.key
  • b: nat
  • D: {a = a} + {a <> a}
  • HeqD: D = Nat.eq_dec a a
  • 1/1(if D then Some b else M.find (elt:=nat) a [ ]) = Some b
Why do I get the error? I have all the right types for unification.
Thanks.
Ram
On Thu, Jan 4, 2018 at 6:47 PM, Ramkumar Ramachandra <artagnon AT gmail.com> wrote:
Hi folks,
I'm trying to use Coq to prove that M.find (referring to FMapAVL) finds an element that exists in the map. Here's my progress so far:
Proof.
intros.
rewrite F.add_o.
induction D.
reflexivity.
rewrite F.empty_o.
Qed.
Somehow, I get stuck with this to prove:
  • a: M.key
  • b: nat
  • b0: a <> a
  • HeqD: right b0 = Nat.eq_dec a a
  • 1/1None = Some b
Which is a falsehood, so I think I did the wrong thing by using "induction D". To eliminate one of the cases of the `if`, I will need to apply `Nat.eq_dec`, and I'm unable to apply it for some strange reason.
Some pointers would be appreciated.
Thanks.
Ram
