coq-club - Re: [Coq-Club] coq-projective-geometry package
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] coq-projective-geometry package
  • Date: Fri, 19 Jan 2018 19:31:46 +0000
  • Accept-language: en-US
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=bajaj AT mit.edu; spf=Pass smtp.mailfrom=bajaj AT mit.edu; spf=None smtp.helo=postmaster AT dmz-mailsec-scanner-1.mit.edu
  • Ironport-phdr: 9a23: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
@Anthony
When you write it seems complete are you saying you worked it out by hand
yourself and then coded it up and found a bug or is the specific logical step
of the proof iron-clad correct and you're merely unfamiliar with the version
control documentation for Coq's more recent instantiations?
Ravi
Sent from my iPhone
> On Jan 19, 2018, at 2:27 PM, Gaëtan Gilbert
> <gaetan.gilbert AT skyskimmer.net>
> wrote:
> That project seems to have branches for various Coq versions. In the 8.4
> branch that position in the failing file is not at the end of the proof,
> suggesting that the most recent version of the development is not
> compatible with 8.4.
> Try the 8.4 branch or a newer Coq.
> Gaëtan Gilbert
>> On 19/01/2018 19:51, Anthony Bordg wrote:
>> Hi,
>> I would like to build the coq package on projective geometry
>> <https://github.com/coq-contribs/projective-geometry> to go through the
>> proofs in the various files with Proof General or coqIDE. But using the
>> make command I got the following error:
>> File
>> "/home/anthony/projective-geometry/Plane/projective_plane_to_Heyting_projective_plane.v",
>> line 146, characters 0-4:
>> Error: Attempt to save an incomplete proof
>> Makefile.coq:245 : la recette pour la cible «
>> Plane/projective_plane_to_Heyting_projective_plane.vo » a échouée
>> make[1]: *** [Plane/projective_plane_to_Heyting_projective_plane.vo]
>> Erreur 1
>> make[1] : on quitte le répertoire « /home/anthony/projective-geometry »
>> Makefile:2 : la recette pour la cible « all » a échouée
>> make: *** [all] Erreur 2
>> However, the aforementioned proof does not seem to be incomplete. I'm
>> using coq v.8.4pl4 on Ubuntu 16.04 LTS. Any help would be welcome.
>> Regards
>> Anthony
>> *PhD. Anthony Bordg
>> *Research Associate
>> *Cambridge University, UK
>> https://sites.google.com/site/anthonybordg/*
