- From: Merlin Göttlinger <megoettlinger AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Reading material on "Program Fixpoint"
- Date: Sat, 20 Jan 2018 13:38:26 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=megoettlinger AT gmail.com; spf=Pass smtp.mailfrom=megoettlinger AT gmail.com; spf=None smtp.helo=postmaster AT mail-io0-f180.google.com
- Ironport-phdr: 9a23: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
Have you read the manual:
Here are a few examples of Program in use:
Cheers,
Merlin
Siddharth Bhat <siddu.druid AT gmail.com> schrieb am Sa., 20. Jan. 2018 um 14:28 Uhr:
SiddharthThanks,3. Use Program to delay obligations, so write "normal" code and fulfil obligations later.2. Directly "implement" stuff with dependent types (like Idris)1. Use tactics to fill in Definition blocks.I've been trying to learn how to write dependently typed code in Coq.As far as I can tell, there are three styles:The problem I face with #1 is that _proving_ things about Definitions encoded this way is impossible for me. For example, if I use omega in some Definition D, I cannot prove anything about D, because on unfolding D, I see the mess that is the omega implementation, I assume.So, for proving things about definitions, #1 is out.#2 is.. challenging, and as a newbie, I find that I often do not know how to express the things I want to say, or do not know how to convince Coq that certain things are impossible (eg: safe indexing into a vector)So, for now, #3 seems easiest.I would like references on the third style of implementing things. Could someone please recommend reading material?
--Sending this from my phone, please excuse any typos!
- [Coq-Club] Reading material on "Program Fixpoint", Siddharth Bhat, 01/20/2018
- Re: [Coq-Club] Reading material on "Program Fixpoint", Merlin Göttlinger, 01/20/2018
- Re: [Coq-Club] Reading material on "Program Fixpoint", Théo Zimmermann, 01/22/2018
- Re: [Coq-Club] Reading material on "Program Fixpoint", Siddharth Bhat, 01/22/2018
