- From: Kevin Sullivan <sullivan.kevinj AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Simple formalization of type of natural deduction proofs
- Date: Mon, 19 Feb 2018 09:50:39 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=sullivan.kevinj AT gmail.com; spf=Pass smtp.mailfrom=sullivan.kevinj AT gmail.com; spf=None smtp.helo=postmaster AT mail-wr0-f171.google.com
- Ironport-phdr: 9a23:7VzS2xAy+WL9TKsiDljbUyQJP3N1i/DPJgcQr6AfoPdwSPv9o8bcNUDSrc9gkEXOFd2Cra4c0KyO6+jJYi8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL1LdrWev4jEMBx7xKRR6JvjvGo7Vks+7y/2+94fcbglUijexe69+IAmrpgjNq8cahpdvJLwswRXTuHtIfOpWxWJsJV2Nmhv3+9m98p1+/SlOovwt78FPX7n0cKQ+VrxYES8pM3sp683xtBnMVhWA630BWWgLiBVIAgzF7BbnXpfttybxq+Rw1DWGMcDwULs5Xymp4aV2Rx/ykCoINTA5/mHZhMJzkaxVvg6uqgdlzILIeoyYLuZycr/fcN4cWGFPXtxRVytEAo6kaoUAEfQBPeder4LgulUOsB++BQ2tBOPx0DBIgGL90Koh0+Q8FQHG2A0gH8wUv3TSttn1N7kdUf60zKnOzzXOdPxW2TLn54jJdhAtu+2DXbV1ccfIz0QkCg3LjlKVqYP/PjOV0PwAs3SV7uV+UeKvhXQrqwZrojigwMonl4rHhpoNx1za6Sl0xJw5KN64RUJhfNKoDphduzuHO4Z0X88vRXxjtjwgxb0co5G7eTAHyJQ5yB7bbPyKa42I7QjiVOaVODt5imhldK6mixa87EStyPDwWtO70FZNqSpFnd3MuW4X2xPP7ciHT+Nx/kan2TmRywDe8v9ILVwwmKbBKJMswqQ8mocNvUnABCP6hUf7gLKOekUh4Oeo6uDnYrv8pp+bMo95khr+Mrkqmsy7AOQ4LBIBX26B9eS/yrLj40z5QLNIjvAtnanZtYrVJcUfpqKjHwBV1YMj5w6lDzi6yNQYgWUHLFVddR2biIjpIkjCL+z8DfeimFuhiyxrxvDDPr35GJrBNHnDkLH7fbZ88UFQ0gQzzcoMr65TX7oGObf4XlL7nN3eFB4wdQKukMj9D9Ao9Y4AWGTHObKdNKLMuFnAsvkyJ+2NeoYT/jXwNfkj5dbhiHY4nRkWeqz/jshfU2yxAvkzexbRWnHrmNpUST5b7Dp7d/TjjRi5aRAWYn+zW6wm4TRiUdCpCI7CQsamh7nThX7nTK0TXXhPDxW3KVmtb5+NAq5eZyebI8snmTsBB+D4Ft0RkCq2vQq/8IJJa+rZ/ipC68Dm3dlxovLJzVQ8rGMtScua1G6JQid/mWZaHzI=
Another way to ask the question: Are there some good pedagogical explications out there of formalizations of natural deduction proof systems, including "-> introduction" as an inference rule, appropriate for early undergraduates, not advanced undergrads or graduate students? And thank you, Stefan, for pointing to the cool "game". I'll give it a go. --Kevin
On Mon, Feb 19, 2018 at 9:16 AM, Kevin Sullivan <sullivan.kevinj AT gmail.com> wrote:
I'm looking for a simplest way to teach my early undergraduate students about natural deduction and/or sequent calculus proof objects without having to get into lambda terms and type systems.The following "POPL tutorial" suggests a standard solution: formalize proofs as values of an inductive type, where the constructors mirror the rules of inference.The rule for implication introduction says (naturally enough) that if you have a function from proofs of A to proofs of B, you can construct a proof of (Impl A B).A straightforward translation of this into Coq, as copied right below this sentence, results in a non-positivity error for the encoding of this inference rule./* variables */Inductive var := mk_var: nat -> var./* propositions in my minimal propositional logic */Inductive prop :=| atom: var -> prop| and: prop -> prop -> prop| impl: prop -> prop -> prop./* proof rules */Inductive proof: prop -> Type :=| axiom: forall A: prop, proof A| andIntro: forall A B: prop, proof A -> proof B -> proof (and A B)| andElimL: forall A B: prop, proof (and A B) -> proof A| andElimR: forall A B: prop, proof (and A B) -> proof B| implElim: forall A B: prop, proof A -> proof (impl A B) -> proof B| implIntro: forall A B: prop, (proof A -> proof B) -> proof (impl A B). (* oops!!! *)What would be the canonical way to represent the same ideas in Coq in a way that works?Again, the aim is a super-straightforward pedagogical explication of rules of natural deduction (or sequent calculus), for a propositional logic only, with the ability to "play around" by building proof terms by explicit application of introduction and elimination inference rules.Kevin
- [Coq-Club] Simple formalization of type of natural deduction proofs, Kevin Sullivan, 02/19/2018
- Re: [Coq-Club] Simple formalization of type of natural deduction proofs, Kevin Sullivan, 02/19/2018
- Re: [Coq-Club] Simple formalization of type of natural deduction proofs, Gert Smolka, 02/19/2018
- Re: [Coq-Club] Simple formalization of type of natural deduction proofs, Daniel Schepler, 02/19/2018
- Re: [Coq-Club] Simple formalization of type of natural deduction proofs, Pierre Courtieu, 02/27/2018
- Re: [Coq-Club] Simple formalization of type of natural deduction proofs, Julien Narboux, 02/28/2018
- Re: [Coq-Club] Simple formalization of type of natural deduction proofs, manoury, 02/28/2018
