- To: Coq-Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Building a constructive term from inside an ML tactic
- Date: Tue, 10 Apr 2018 02:35:58 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=tringer AT cs.washington.edu; spf=None smtp.mailfrom=tringer AT cs.washington.edu; spf=None smtp.helo=postmaster AT mail-vk0-f43.google.com
- Ironport-phdr: 9a23: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
let coq_init_specif = ModPath.MPfile (DirPath.make (List.map Id.of_string ["Specif"; "Init"; "Coq"])) let sigT = mkInd (MutInd.make1 (KerName.make2 coq_init_specif (Label.make "sigT")), 0)
let existT = mkConstruct (fst (destInd sigT), 1)
I am writing a tactic to simplify expressions. As an example consider the following:
Fixpoint beq a b :=
match a,b with
| 0,0 => true
| (S x),(S y) => beq x y
| _,_ => false
end.
Fixpoint blt a b :=
match a,b with
| _,0 => false
| (S x),(S y) => blt x y
| 0,(S x) => true
end.
Theorem test: forall x y, q(x,y) = orb (negb (beq x y)) (negb(blt x y)).
Proof.
arewrite.
The "arewrite" tactic can reduce this theorem to "forall x y, q(x,y) = true". The tactic needs to construct the inductive term "true". I tried the following piece of ml code which did not work:
let true_term = Term.mkApp (mkConstructorUi (Lib_coq.init_constant ["Coq"; "Init"; "Datatypes"] "bool") 1) [||]
The problem seems to be that I need to convert a constr object to a pinductive object. Can someone give me a piece of ml code to construct the term "true"?
- Ken
- [Coq-Club] Building a constructive term from inside an ML tactic, Kenneth Roe, 04/10/2018
- Re: [Coq-Club] Building a constructive term from inside an ML tactic, Talia Ringer, 04/10/2018
- Re: [Coq-Club] Building a constructive term from inside an ML tactic, Emilio Jesús Gallego Arias, 04/11/2018
