coq-club - [Coq-Club] Can I apply "Extraction Inline" and "Extraction Constant" for definitions hidden by a module?
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Can I apply "Extraction Inline" and "Extraction Constant" for definitions hidden by a module?
  • Date: Tue, 10 Apr 2018 12:27:35 +0900
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=pi8027 AT gmail.com; spf=Pass smtp.mailfrom=pi8027 AT gmail.com; spf=None smtp.helo=postmaster AT mail-yb0-f180.google.com
  • Ironport-phdr: 9a23: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
Hello,
I tried to apply "Extraction Inline" and "Extraction Constant" for
definitions hidden by using "Module Type" and "Module" in two ways,
but both of them are failed. Do you have any idea for solving this?
Best Regards,
Kazuhiko
Require Extraction.
Extraction Language Ocaml.
Extract Inductive
  nat => "int"
           ["0" "succ"]
           "(fun zero succ n -> if n = 0 then zero () else succ (n - 1))".
Module Type ASig.
Parameter x : nat.
End ASig.
Module A : ASig.
Definition hidden := 10.
Definition x := hidden * hidden.
Extract Inlined Constant x => "10".
End A.
Fail Print A.hidden. (* A.hidden is not accessible from outside of A. *)
Extraction A.
A.hidden is not replaced by the constant and not inlined:
module A =
 struct
  (** val hidden : int **)
  let hidden =
    succ (succ (succ (succ (succ (succ (succ (succ (succ (succ 0)))))))))
  (** val x : int **)
  let x =
    mul hidden hidden
 end
Fail Extraction Inline hidden.
Fail Extract Constant x => "10".
