Re: [Coq-Club] How can you build a coinductive memoization table for recursive functions over binary trees?
- From: Joachim Breitner <mail AT joachim-breitner.de>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How can you build a coinductive memoization table for recursive functions over binary trees?
- Date: Thu, 26 Apr 2018 11:43:32 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mail AT joachim-breitner.de; spf=Neutral smtp.mailfrom=mail AT joachim-breitner.de; spf=None smtp.helo=postmaster AT hermes.serverama.de
- Ironport-phdr: 9a23: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
…but then again, this is not at all addressing the question on how to
memoize recursive functions, so I guess my response is just noise …
sorry
Joachim
Am Donnerstag, den 26.04.2018, 11:41 -0400 schrieb Joachim Breitner:
> Hi,
> you might enjoy looking at
> https://github.com/antalsz/hs-to-coq/tree/master/examples/coinduction
> where I implement such a memo table in Haskell, convert it to Coq using
> hs-to-coq (the generated file is not in the git repo, so I attached it
> to this mail), and then in MemoProofs.v show that it preserves the
> semantics of the memoized functions.
> The Time commands at the end of this function show that memoization
> actually works in Coq!
> Time Eval vm_compute in slowFib 25. (* Finished transaction in 2.248 secs *)
> Time Eval vm_compute in slowFib 25. (* Finished transaction in 2.233 secs *)
> Time Eval vm_compute in cachedFib 25. (* Finished transaction in 2.203 secs
> Time Eval vm_compute in cachedFib 25. (* Finished transaction in 0. secs *)
> Time Eval vm_compute in cachedFib 26. (* Finished transaction in 3.579 secs
> Time Eval vm_compute in cachedFib 26. (* Finished transaction in 0. secs *)
> Cheers,
> Joachim
> Am Mittwoch, den 25.04.2018, 12:11 -0700 schrieb
> roconnor AT theorem.ca:
> > I've posted this question on the cstheory stack exchange at
> > https://cstheory.stackexchange.com/questions/40631/how-can-you-build-a-coinductive-memoization-table-for-recursive-functions-over-b
> > but I'm hoping to reach a wider audience by also asking here on the Coq
> > Club
> > mailing list. I copy my question below.
> > The StreamMemo library for Coq illustrates how to memoize a function f :
> > nat ->
> > A over the natural numbers. In particular when f (S n) = g (f n), the
> > imemo_make shares the computation of recursive calls.
> > Suppose instead of natural numbers, we want to memoize recursive
> > functions over
> > binary trees:
> > Inductive binTree : Set :=
> > > Leaf : binTree
> > > Branch : binTree -> binTree -> binTree.
> > Suppose we have a function f : binTree -> A that is structurally
> > recursive,
> > meaning that there is a function g : A -> A -> A such that f (Branch x y)
> > = g
> > (f x) (f y). How do we build a similar memo table for f in Coq such that
> > the
> > recursive computations are shared?
> > In Haskell, it is not too hard to build such a memo table (see MemoTrie
> > for
> > example) and tie-the-knot. Clearly such memo tables are productive. How
> > can we
> > arrange things to convince a dependently typed language to accept such
> > knot
> > tying is productive?
> > Even building a memotrie data type for binary trees is difficult in Coq.
> > The
> > natural solution calls for using a Bushy Datatype (see
> > https://www.cs.ox.ac.uk/richard.bird/online/BirdMeertens98Nested.pdf)
> > which
> > doesn't pass Coq's positivity check (but does seem to pass Agda's
> > positivity
> > check; maybe Christine Paulin could even further relax Coq's positivity
> > check.
> > :) ). At the risk of prejudicing the reader, I have a gist of how I've
> > worked
> > around this to define a memotrie data type for binary trees in Coq at
> > https://gist.github.com/roconnor/52375c3a81c927c5a8234be858f9830b
> > My above solution to building a memotrie is moderately contrived and
> > adhoc, so
> > I encourage those intrested in this problem to try a solution themselves
> > first
> > before reading my gist. You may come up with a better solution than what
> > I
> > have.
> > The memotrie I build in my gist doesn't memoize recursive calls of a
> > structurally recursive function over binary trees. At the end I write out
> > the
> > type of solution one would write in Haskell to build an example memotrie
> > that
> > memoizes recurive calls. However, this definition fails that corecursive
> > guard
> > check (and rightly so I think).
> > I don't know how to build a memotrie to memoize recursive calls in a
> > structurally recursive function. I'm hoping someone one the mailing list
> > might
> > know a solution.
> > Russell O'Connor <http://r6.ca/>
Joachim Breitner
http://www.joachim-breitner.de/
signature.asc
Description: This is a digitally signed message part
- [Coq-Club] How can you build a coinductive memoization table for recursive functions over binary trees?, roconnor, 04/25/2018
- Re: [Coq-Club] How can you build a coinductive memoization table for recursive functions over binary trees?, Joachim Breitner, 04/26/2018
- Re: [Coq-Club] How can you build a coinductive memoization table for recursive functions over binary trees?, Li-yao Xia, 04/26/2018
