coq-club - Re: [Coq-Club] How can you build a coinductive memoization table for recursive functions over binary trees?
  • To: Joachim Breitner <mail AT joachim-breitner.de>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] How can you build a coinductive memoization table for recursive functions over binary trees?
  • Date: Thu, 26 Apr 2018 11:48:46 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=lysxia AT gmail.com; spf=Pass smtp.mailfrom=lysxia AT gmail.com; spf=None smtp.helo=postmaster AT mail-vk0-f53.google.com
  • Ironport-phdr: 9a23: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
What happens if you write Russel's memoOpX at the end in Haskell and run hs-to-coq on it?
Li-yao
On 04/26/2018 11:43 AM, Joachim Breitner wrote:
…but then again, this is not at all addressing the question on how to
memoize recursive functions, so I guess my response is just noise …
sorry
Joachim
Am Donnerstag, den 26.04.2018, 11:41 -0400 schrieb Joachim Breitner:
Hi,
you might enjoy looking at
https://github.com/antalsz/hs-to-coq/tree/master/examples/coinduction
where I implement such a memo table in Haskell, convert it to Coq using
hs-to-coq (the generated file is not in the git repo, so I attached it
to this mail), and then in MemoProofs.v show that it preserves the
semantics of the memoized functions.
The Time commands at the end of this function show that memoization
actually works in Coq!
Time Eval vm_compute in slowFib 25. (* Finished transaction in 2.248 secs *)
Time Eval vm_compute in slowFib 25. (* Finished transaction in 2.233 secs *)
Time Eval vm_compute in cachedFib 25. (* Finished transaction in 2.203 secs *)
Time Eval vm_compute in cachedFib 25. (* Finished transaction in 0. secs *)
Time Eval vm_compute in cachedFib 26. (* Finished transaction in 3.579 secs *)
Time Eval vm_compute in cachedFib 26. (* Finished transaction in 0. secs *)
Cheers,
Joachim
Am Mittwoch, den 25.04.2018, 12:11 -0700 schrieb
roconnor AT theorem.ca:
I've posted this question on the cstheory stack exchange at
https://cstheory.stackexchange.com/questions/40631/how-can-you-build-a-coinductive-memoization-table-for-recursive-functions-over-b
but I'm hoping to reach a wider audience by also asking here on the Coq Club
mailing list. I copy my question below.
The StreamMemo library for Coq illustrates how to memoize a function f : nat
A over the natural numbers. In particular when f (S n) = g (f n), the
imemo_make shares the computation of recursive calls.
Suppose instead of natural numbers, we want to memoize recursive functions
over
binary trees:
Inductive binTree : Set :=
Leaf : binTree
Branch : binTree -> binTree -> binTree.
Suppose we have a function f : binTree -> A that is structurally recursive,
meaning that there is a function g : A -> A -> A such that f (Branch x y) = g
(f x) (f y). How do we build a similar memo table for f in Coq such that the
recursive computations are shared?
In Haskell, it is not too hard to build such a memo table (see MemoTrie for
example) and tie-the-knot. Clearly such memo tables are productive. How can we
arrange things to convince a dependently typed language to accept such knot
tying is productive?
Even building a memotrie data type for binary trees is difficult in Coq. The
natural solution calls for using a Bushy Datatype (see
https://www.cs.ox.ac.uk/richard.bird/online/BirdMeertens98Nested.pdf) which
doesn't pass Coq's positivity check (but does seem to pass Agda's positivity
check; maybe Christine Paulin could even further relax Coq's positivity check.
:) ). At the risk of prejudicing the reader, I have a gist of how I've worked
around this to define a memotrie data type for binary trees in Coq at
https://gist.github.com/roconnor/52375c3a81c927c5a8234be858f9830b
My above solution to building a memotrie is moderately contrived and adhoc, so
I encourage those intrested in this problem to try a solution themselves first
before reading my gist. You may come up with a better solution than what I
have.
The memotrie I build in my gist doesn't memoize recursive calls of a
structurally recursive function over binary trees. At the end I write out the
type of solution one would write in Haskell to build an example memotrie that
memoizes recurive calls. However, this definition fails that corecursive
guard
check (and rightly so I think).
I don't know how to build a memotrie to memoize recursive calls in a
structurally recursive function. I'm hoping someone one the mailing list
might
know a solution.
Russell O'Connor <http://r6.ca/>
