- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Will there be a pdf manual for 8.8.0?
- Date: Thu, 10 May 2018 17:33:58 +0000
- Accept-language: de-DE, en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=michael.soegtrop AT intel.com; spf=Pass smtp.mailfrom=michael.soegtrop AT intel.com; spf=None smtp.helo=postmaster AT mga11.intel.com
- Dlp-product: dlpe-windows
- Dlp-reaction: no-action
- Dlp-version: 11.0.200.100
- Ironport-phdr: 9a23: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
Dear Théo,
It is ok – the new format is indeed easier to read. Just it would be nice to have an easy way to download it. Or maybe the installer should install the documentation, if it consists out of many files. I sometimes do Coq in places with bad network infrastructure.
I can take care of this for Windows.
Best regards,
Michael
From: coq-club-request AT inria.fr [mailto:coq-club-request AT inria.fr]
On Behalf Of Théo Zimmermann
Dear Michael, There won't be a pdf manual for Coq 8.8.0. If you think it is unfortunate, please open a new issue: so far the lack of clear use cases has not permitted to motivate anyone to work on the additional infrastructure that this would require. The problem of the wrong mention on the website had indeed been reported a couple times already and should now be fixed. Thanks, Théo
Le jeu. 10 mai 2018 à 13:49, Soegtrop, Michael <michael.soegtrop AT intel.com> a écrit :
Intel Deutschland GmbH |
- [Coq-Club] Will there be a pdf manual for 8.8.0?, Soegtrop, Michael, 05/10/2018
- Re: [Coq-Club] Will there be a pdf manual for 8.8.0?, Théo Zimmermann, 05/10/2018
- RE: [Coq-Club] Will there be a pdf manual for 8.8.0?, Soegtrop, Michael, 05/10/2018
- Re: [Coq-Club] Will there be a pdf manual for 8.8.0?, Clément Pit-Claudel, 05/11/2018
- Re: [Coq-Club] Will there be a pdf manual for 8.8.0?, Théo Zimmermann, 05/13/2018
- RE: [Coq-Club] Will there be a pdf manual for 8.8.0?, Soegtrop, Michael, 05/14/2018
