- From: Clément Pit-Claudel <cpitclaudel AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Will there be a pdf manual for 8.8.0?
- Date: Thu, 10 May 2018 18:31:51 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=cpitclaudel AT gmail.com; spf=Pass smtp.mailfrom=cpitclaudel AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f170.google.com
- Ironport-phdr: 9a23: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
Hi Michael and Théo,
> Or maybe the installer should install the documentation, if it consists out
> of many files.
I think we should be able to ask Sphinx for a one-page copy of the manual,
which should be easy to download.
> There won't be a pdf manual for Coq 8.8.0. If you think it is unfortunate,
> please open a new issue: so far the lack of clear use cases has not
> permitted to motivate anyone to work on the additional infrastructure that
> this would require.
The original prototype I wrote was supposed to allow building PDFs, but
indeed the version that's in the repo currently can't build a valid PDF.
There are very few blocking issues, though (maybe 3-5 LaTeX mistakes and a
few reST issues). I've uploaded a copy of the manual generated by Sphinx
after fixing these errors to https://people.csail.mit.edu/cpitcla/coq-8.8.pdf
(2.2MB a bit too heavy to attach). There are still presentation issues, but
if there is interest in a PDF manual they should not be difficult to fix.
Building a LaTeX copy of the manual would give us a good way to check the
correctness of embedded math, by the way.
Cheers,
Clément.
On 2018-05-10 13:45, Théo Zimmermann wrote:
> Indeed, it would be great to have the Windows installer ship the
> documentation. The new Python dependencies of the manual should be easier
> to install on Windows. So far the AppVeyor infrastructure used to build the
> installer has been very close to timeout and adding the doc to it would be
> probably too much, but the move to GitLab CI should solve this by allowing
> longer timeouts.
> Best,
> Théo
> Le jeu. 10 mai 2018 à 19:34, Soegtrop, Michael
> <michael.soegtrop AT intel.com
> <mailto:michael.soegtrop AT intel.com>>
> a écrit :
> Dear Théo,____
> __ __
> It is ok – the new format is indeed easier to read. Just it would be
> nice to have an easy way to download it. Or maybe the installer should
> install the documentation, if it consists out of many files. I sometimes do
> Coq in places with bad network infrastructure.____
> __ __
> I can take care of this for Windows.____
> __ __
> Best regards,____
> __ __
> Michael____
> __ __
> *From:*coq-club-request AT inria.fr
> <mailto:coq-club-request AT inria.fr>
> [mailto:coq-club-request AT inria.fr
> <mailto:coq-club-request AT inria.fr>]
> *On Behalf Of *Théo Zimmermann
> *Sent:* Thursday, May 10, 2018 5:36 PM
> *To:*
> <mailto:coq-club AT inria.fr>
> *Subject:* Re: [Coq-Club] Will there be a pdf manual for 8.8.0?____
> __ __
> Dear Michael,____
> unfortunate, please open a new issue: so far the lack of clear use cases
> has not permitted to motivate anyone to work on the additional
> infrastructure that this would require.____
> The problem of the wrong mention on the website had indeed been
> reported a couple times already and should now be fixed.____
> Thanks,____
> Théo____
> __ __
> Le jeu. 10 mai 2018 à 13:49, Soegtrop, Michael
> a écrit :____
> Dear Coq Team,____
> ____
> I wonder if there are plans to publish a pdf manual for Coq 8.8.0
> and future versions, or if this was dropped in favor of the new
> documentation format.____
> ____
> A note: this page: https://coq.inria.fr/documentation states that a
> PDF version can be downloaded from the release page
> https://github.com/coq/coq/releases/tag/V8.8.0 , but this doesn’t seem to
> be the case.____
> ____
> Best regards,____
> ____
> Michael____
> ____
> Intel Deutschland GmbH
> Registered Address: Am Campeon 10
> <https://maps.google.com/?q=Am+Campeon+10&entry=gmail&source=g>-12, 85579
> Neubiberg, Germany
> Tel: +49 89 99 8853-0, www.intel.de <http://www.intel.de>
> Managing Directors: Christin Eisenschmid, Christian Lamprechter
> Chairperson of the Supervisory Board: Nicole Lau
> Registered Office: Munich
> Commercial Register: Amtsgericht Muenchen HRB 186928____
> Neubiberg, Germany
- [Coq-Club] Will there be a pdf manual for 8.8.0?, Soegtrop, Michael, 05/10/2018
- Re: [Coq-Club] Will there be a pdf manual for 8.8.0?, Théo Zimmermann, 05/10/2018
- RE: [Coq-Club] Will there be a pdf manual for 8.8.0?, Soegtrop, Michael, 05/10/2018
- Re: [Coq-Club] Will there be a pdf manual for 8.8.0?, Clément Pit-Claudel, 05/11/2018
- Re: [Coq-Club] Will there be a pdf manual for 8.8.0?, Théo Zimmermann, 05/13/2018
- RE: [Coq-Club] Will there be a pdf manual for 8.8.0?, Soegtrop, Michael, 05/14/2018
