coq-club - Re: [Coq-Club] Calling things from a parent module into another module as neat as possible
  • From: Sylvain Boulmé <Sylvain.Boulme AT univ-grenoble-alpes.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Calling things from a parent module into another module as neat as possible
  • Date: Wed, 6 Jun 2018 09:27:44 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=Pass smtp.mailfrom=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=None smtp.helo=postmaster AT zm-mta-out-2.u-ga.fr
  • Ironport-phdr: 9a23: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
Hi Milad,
Le 06/06/2018 à 07:50, Milad Ketabii a écrit :
Hi there!
I have a problem, for which a solution already is there. However, I am looking for a better way of accomplishing the task.
Here, I will first explain the problem itself, as much simply as possible. Then I mention the crazy solution which I have. But I hope someone would kindly hint at a superior approach.
*The problem and a crazy solution:*
I have a formalisation which I intend to break into a base file and some modules, each of which calls this base in.
The base formalisation has variables. These variables are used inside each module as well. We finally would extract executable program into Haskell.
The base is constituted of some sections. To make the variables in the base file available to the modules (without instantiating them), I have made the out-most part of the base file as a module, rather than a section. This prevents errors that I would get by trying to compile the modules.
I do not fully understand your current solution: is this "out-most" part a module in parameter of each module ? (Now, are your modules actually functors ?)
However, the hassle is that I need to put the name of the base module in front of every variable, definition, and function which are celled in the modules.
Whatever module "Base" is: a parameter or an actual implementation, you only need to write "Import Base." in each module that uses "Base" in order to solve your problem.
Regards,
Sylvain.
