coq-club - Re: [Coq-Club] Calling things from a parent module into another module as neat as possible
  • From: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Calling things from a parent module into another module as neat as possible
  • Date: Wed, 6 Jun 2018 10:58:06 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=pierre.courtieu AT gmail.com; spf=Pass smtp.mailfrom=pierre.courtieu AT gmail.com; spf=None smtp.helo=postmaster AT mail-oi0-f48.google.com
  • Ironport-phdr: 9a23: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
Hi,
There may be a confusion. Indeed as Sylvain said "Import" should do
the trick but you jhave to know that a *file* is always compiled as a
module by coqc. So you probably don't need to define a module
explicitely for Base. Just put it in a file called Base.v (with no
"Module Base." inside) and do "Import Base." at the top of M1 and M2
(you also need to "Require Base." and you can do both with "Require
Import Base.").
If you have a "Module Base." in Base.v then you need to "Include Base.Base.".
Hope this helps
P.
