[Coq-Club] On the extraction and parametricity of random generators as sets of values
- To: coq-club AT inria.fr
- Subject: [Coq-Club] On the extraction and parametricity of random generators as sets of values
- Date: Fri, 22 Jun 2018 13:07:15 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=lysxia AT gmail.com; spf=Pass smtp.mailfrom=lysxia AT gmail.com; spf=None smtp.helo=postmaster AT mail-ua0-f179.google.com
- Ironport-phdr: 9a23:YucB/xOpI0KSvaSTqVYl6mtUPXoX/o7sNwtQ0KIMzox0Lfr9rarrMEGX3/hxlliBBdydt6oZzbKO+4nbGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2aFLduGC94iAPERvjKwV1Ov71GonPhMiryuy+4ZLebxlIiTanfb9+MAi9oBnMuMURnYZsMLs6xAHTontPdeRWxGdoKkyWkh3h+Mq+/4Nt/jpJtf45+MFOTav1f6IjTbxFFzsmKHw65NfqtRbYUwSC4GYXX3gMnRpJBwjF6wz6Xov0vyDnuOdxxDWWMMvrRr8zRTmv4aVmRRHxhCsbODMy7WXbh8xsgK5eph+quh5xzJPOYIyNNPRwY73Tc9AUS2VPUcleSyNPD5igb4YNFecNIfpUoof/qlYIsBCwBROsBOTqyjJQgHH23LQ20uQ7HgHBwQcvHtMOv27Jp9jyMKcTUfu1zabJzTrZdP5W1jL955LJchAlu/2DQbVwcc/IxEQpCgjLgFKQqYn/MDOU0OQAq2eb7+t8VeKvlm4osBt9rSSoxscpjITCm4Ebykjc+Cln3Io4Ice0RU17bNK+DpdcqiOXO5FrTs4gR2xkoDg2xqEHtJKhYSQG1pQqywTeZvCZaYSE/BLuWeCMKjlinn1lYqiwhxOq/Eig1OL8Us603U5PriVfk9nMsmkB1wHJ5cSbU/d98Fqt1DSL2gzJ5eFEJkc0laXfK5E/2LI/ip0TsUHbEi/3nkX5krOWe1069uS07+nreLbrq5+GO4Nqlw3zML4iltG9DOk8KgQOWnKU+eW41L3t5035R7BKg+UykqjZq5DbKsUbqbSiDg9a14Ys8Re/DzO83NsEmnkHKUpJeAibgIjxJ1HOPPf4AO+jjFSriTdn3uzJPrn8AprWNXXDi7fgfbNl60FG0gYzzNZf54hVCr4bOv7zVFXx55TkCUoyNBXxyOL6Av180JkfUCSBGPy3KqTX5HuJo/MmJKG8ZYZd7DLsMOgk7tbhiHY4nRkWeqz/jshfU2yxAvkzexbRWnHrmNpUTD9T71gOCdfygVjHagZ9InO7XqYy/DY+Udv0AoLKR4Tri7uEjn7iQs9mI1teA1XJKk/GMp2eUq5VOi2XK85l1DcDUOr5EtJz5VSVrAb/joFfAK/U9ykf78yx0dF046jOnEl3+2UrXoKS1GaCS2wylWQNFWc7
Hello Coq-club,
Sorry for the length. I have a few questions about making code efficient for extraction and parametricity in Coq.
In QuickChick, a random generator is a function of type "G value := seed -> value", and to reason about it, we interpret it as the set of values it may generate, i.e., its image as a function. This assumes the seed is a true source of randomness, for example represented as an arbitrary stream of bits: "G value := stream -> value" (or tree for splittable randomness). But of course, for performance, we would rather evaluate the function with a finite-state PRNG (of type "seed").
(QuickChick currently axiomatizes the first interpretation, and extracts these axioms to the second.)
In order to support the two interpretations more faithfully, we can generalize the type of generators to "G value := forall `(RNG s), s -> value", for some appropriate class "RNG" that has instances for "seed" and "stream".
Class RNG (s : Type) := {
next : s -> bool * s;
Now we can run such a generator quickly with a "seed", and we can reason about it as a set of values, via a semantic function "sem : G value -> set value" where "x \in sem g = exists (r : stream), g _ _ r = x" (specializing "g" at "stream").
1. Dictionary erasure by extraction
Definition G value := forall `(RNG s), s -> value.
This generalization of the type of generators means they must take an extra parameter for the the RNG dictionary. But for extraction we really want to specialize generators at type "seed".
- Can OCaml optimize away that constant parameter?
- Can we tell extraction to specialize that parameter?
- Is there a different representation which extracts to something more efficient, and which also works well for formalization? (Module functors seem too cumbersome to relate different instantiations as I do below.)
2. Shrinking the formalization gap by parametricity
One thing we can try to prove is that the set of values generated using any RNG "s" is a subset of those generated using "stream". It seems feasible case-by-case, but is that provable as a general theorem?
Conjecture soundness :
forall `{RNG s} (g : G value),
(exists (r : s), g _ _ r = x) -> x \in sem g.
That seems to require an argument of parametricity that is not internalized in Coq AFAICT. This project https://github.com/parametricity-coq/paramcoq seems relevant but I didn't have an opportunity to try it as it requires Coq 8.5. Are there up-to-date alternatives?
I hoped that gap would be only a theoretical question that could be ignored in practice. However, there is at least one existing generator combinator where that matters, a monadic bind function where the continuation also expects a proof that its input was generated from the first argument "g":
Definition bindGen' :
forall (g : G A), (forall a, a \in sem g -> G B) -> G B.
The problem is that the "sem" function only considers the specialization of the RNG at "stream", but the result of "bindGen'" must evaluate "g" parametrically in the RNG "s". The "soundness" theorem above is precisely what would relate those specializations.
How can we define "bindGen'", if that "soundness" theorem cannot be proved? One solution I'm thinking of is to make G a sigma carrying proofs of instances of that theorem.
Regards,
Li-yao
- [Coq-Club] On the extraction and parametricity of random generators as sets of values, Li-yao Xia, 06/22/2018
- Re: [Coq-Club] On the extraction and parametricity of random generators as sets of values, Gabriel Scherer, 06/22/2018
