coq-club - Re: [Coq-Club] On the extraction and parametricity of random generators as sets of values
  • From: Gabriel Scherer <gabriel.scherer AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] On the extraction and parametricity of random generators as sets of values
  • Date: Fri, 22 Jun 2018 22:50:47 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gabriel.scherer AT gmail.com; spf=Pass smtp.mailfrom=gabriel.scherer AT gmail.com; spf=None smtp.helo=postmaster AT mail-io0-f178.google.com
  • Ironport-phdr: 9a23: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
> The problem is that the "sem" function only considers the specialization of
> the RNG at "stream", but the result of "bindGen'" must evaluate "g"
> parametrically in the RNG "s".
What if you defined sem to be wider?
Definition sem value (g : G value) : value -> Prop :=
fun x => (exists s `(RNG s) r, g s _ r = x).
(This corresponds to making the soundness result hold trivially by
making both sides equal.)
> One solution I'm thinking of is to make G a sigma carrying proofs of
> instances of that theorem.
Indeed it works. Given some well-chosen `same_stream` coinductive (see
at the end of this email), you can define
Record ParamG value := {
get : G value;
param : (forall s `(RNG s) rs rstream,
same_stream (stream_of s _ rs) rstream -> get s _ rs = get stream
_ rstream);
and then prove soundness for ParamG. Using a parametricity plugin
might automatically derive the "param" proofs for the (G value)
combinators that you implement in practice. (It would derive the
binary version, saying you get equal values from any two RNGs whose
streams are the same).
Class RNG (s : Type) := {
next : s -> bool * s;
CoInductive stream := Next : bool -> stream -> stream.
CoFixpoint stream_of s `(RNG s) (st : s) : stream :=
let '(b, st_next) := next st in
Next b (stream_of s _ st_next).
CoInductive same_stream : stream -> stream -> Prop :=
| Same : forall b1 r1 b2 r2,
b1 = b2 ->
same_stream r1 r2 ->
same_stream (Next b1 r1) (Next b2 r2)
CoFixpoint same_stream_refl : forall st, same_stream st st.
destruct st. constructor; auto.
Qed.
Definition G value := forall s `(RNG s), s -> value.
Definition next_stream '(Next b s) := (b, s).
Instance rng_stream : RNG stream := { next := next_stream }.
get : G value;
_ rstream);
Lemma soundness_for_paramG :
forall s `{RNG s} value (g : ParamG value) x,
(exists (r : s), get _ g _ _ r = x) -> (exists (r : stream), get _
g _ _ r = x).
intros s rng value g x [st H].
exists (stream_of _ _ st).
symmetry. subst x.
apply param.
apply same_stream_refl.
Qed.
The definitions below are not necessary above, but they are (1)
trickier than I hoped and (2) necessary to connect the two ways to
state parametricity,
same_stream (stream_of s) st
and
same_stream (stream_of s1) (stream_of s2)
Definition open_stream '(Next b st) := Next b st.
Definition open st : (st = open_stream st) :=
let '(Next b st) := st in eq_refl.
CoFixpoint same_stream_of st : same_stream (stream_of stream rng_stream st)
st.
destruct st.
match goal with [ |- same_stream ?S _ ] => rewrite (open S) end.
constructor; auto.
Qed.
On Fri, Jun 22, 2018 at 7:07 PM, Li-yao Xia
<lysxia AT gmail.com>
wrote:
> Hello Coq-club,
> Sorry for the length. I have a few questions about making code efficient for
> extraction and parametricity in Coq.
> In QuickChick, a random generator is a function of type "G value := seed ->
> value", and to reason about it, we interpret it as the set of values it may
> generate, i.e., its image as a function. This assumes the seed is a true
> source of randomness, for example represented as an arbitrary stream of
> bits: "G value := stream -> value" (or tree for splittable randomness). But
> of course, for performance, we would rather evaluate the function with a
> finite-state PRNG (of type "seed").
> (QuickChick currently axiomatizes the first interpretation, and extracts
> these axioms to the second.)
> In order to support the two interpretations more faithfully, we can
> generalize the type of generators to "G value := forall `(RNG s), s ->
> value", for some appropriate class "RNG" that has instances for "seed" and
> "stream".
> Now we can run such a generator quickly with a "seed", and we can reason
> about it as a set of values, via a semantic function "sem : G value -> set
> value" where "x \in sem g = exists (r : stream), g _ _ r = x" (specializing
> "g" at "stream").
> 1. Dictionary erasure by extraction
> Definition G value := forall `(RNG s), s -> value.
> This generalization of the type of generators means they must take an extra
> parameter for the the RNG dictionary. But for extraction we really want to
> specialize generators at type "seed".
> - Can OCaml optimize away that constant parameter?
> - Can we tell extraction to specialize that parameter?
> - Is there a different representation which extracts to something more
> efficient, and which also works well for formalization? (Module functors
> seem too cumbersome to relate different instantiations as I do below.)
> 2. Shrinking the formalization gap by parametricity
> One thing we can try to prove is that the set of values generated using any
> RNG "s" is a subset of those generated using "stream". It seems feasible
> case-by-case, but is that provable as a general theorem?
> Conjecture soundness :
> forall `{RNG s} (g : G value),
> (exists (r : s), g _ _ r = x) -> x \in sem g.
> That seems to require an argument of parametricity that is not internalized
> in Coq AFAICT. This project https://github.com/parametricity-coq/paramcoq
> seems relevant but I didn't have an opportunity to try it as it requires Coq
> 8.5. Are there up-to-date alternatives?
> I hoped that gap would be only a theoretical question that could be ignored
> in practice. However, there is at least one existing generator combinator
> where that matters, a monadic bind function where the continuation also
> expects a proof that its input was generated from the first argument "g":
> Definition bindGen' :
> forall (g : G A), (forall a, a \in sem g -> G B) -> G B.
> parametrically in the RNG "s". The "soundness" theorem above is precisely
> what would relate those specializations.
> How can we define "bindGen'", if that "soundness" theorem cannot be proved?
> Regards,
> Li-yao
