- To: coq-club AT inria.fr, Xuanrui Qi <xqi01 AT cs.tufts.edu>
- Subject: Re: [Coq-Club] Weird import problem?
- Date: Thu, 27 Sep 2018 15:24:35 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=lysxia AT gmail.com; spf=Pass smtp.mailfrom=lysxia AT gmail.com; spf=None smtp.helo=postmaster AT mail-vs1-f49.google.com
- Ironport-phdr: 9a23:AN2qdRb9HXVJqx3dFfg6lI7/LSx+4OfEezUN459isYplN5qZoMu5bnLW6fgltlLVR4KTs6sC17KJ9fi4EUU7or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6arXK99yMdFQviPgRpOOv1BpTSj8Oq3Oyu5pHfeQpFiCa/bL9oMBm6sRjau9ULj4dlNqs/0AbCrGFSe+RRy2NoJFaTkAj568yt4pNt8Dletuw4+cJYXqr0Y6o3TbpDDDQ7KG81/9HktQPCTQSU+HQRVHgdnwdSDAjE6BH6WYrxsjf/u+Fg1iSWIdH6QLYpUjm58axlVAHnhzsGNz4h8WHYlMpwjL5AoBm8oxBz2pPYbJ2JOPZ7eK7WYNEUSndbXstJSiJPHI28YYsMAeQPM+lXoIvyqEcBoxalGQmhBvnixiNUinL436A31fkqHwHc3AwnGtIDqHLarNTsOKYSS++1y7TDwjTCb/xMxDzw74zIcxA6ofCDXLJ/a9HcyUYqFwzfj1WQrZbpMC+S1uQIqmWW6fdrW+G3i2M/tQ19vjyiyt0vh4TJnI4Z1E3I+CdjzIs6IdC0UFB3bcKlHZdKqi2WKYt7TtkjTm12oio21L0LtJimdyYQ0psn3QTQa/mffoiI/B3jUOGRLC99hH1/ebK/gw++8Va7yuHhT8W03llHoy5fntnDsXAN0BPT6syZRfdn4kih3jOP2xjS6uFCP080ibLWJ4A9zrM0jJYeskTOEjXolEnrjqKabEop9+yw5+TieLrmp5ucN4FuigH5N6Qjgsi/AOQjMgkBXmiU4/+x1LLm/ULjQbVKiuc6nbXesJDfPcgbvLK2AxdJ0oY/7BayFyup0NMBnXUeMF1FfA+HgJPyNlHVIPH4CO+/jE62nDdqwfDGJLzhDY/XInjNireyNYp6vkVb0U84yc1Vz5NSELAIZvzpHgfBqdXeFAI4ezW1i7L3EdQlj6sVQiSTH6GFK+XfvULetcw1JOzZQI5QqT/6Y8gk7ra6iW4iiV4UVaas1JoTLnu/G6I1cA2ifXPwj4JZQi8xtQ0kQbmv0QXaCG8BVzOJR6s5owoDJsejBIbHSJqqheXYjii+F5xSIGtBDwLVSCu6R8C/Q/4JLRmqDIp5iDVdDOquToYg0Velswqok+M6fNqRwTURsNfY7PYw5+DXkktvpzl9DsDYzXrUCm8ozyUHQDg52K05qkt4mA+O
Hi Xuanrui,
Try
Require Import Equations.Equations.
Looking at the "Print LoadPath" output, "Equations" is the path to the Equations library, but that is not a path to an actual file, which "Require" expects.
The logical path "Equations.Equations" refers to the module .../user-contrib/Equations/Equations.vo which can thus be loaded.
Li-yao
On 9/27/18 3:17 PM, Xuanrui Qi wrote:
Hello all,
I appear to have run into a weird Import problem in Coq. I have
installed the "coq-equations" package using opam, but when I try to
Require Import the package:
Coq < Require Import Equations.
Toplevel input, characters 15-24:
Require Import Equations.Error: Unable to locate library Equations.
However, if I issue the "Print LoadPath." command, I can see that
Equations is in the load path!
Coq < Print LoadPath.
Logical Path / Physical path:
<> /home/xuanrui
<> /home/xuanrui/.opam/4.07.0/lib/coq/user-contrib
Equations /home/xuanrui/.opam/4.07.0/lib/coq/user-contrib/Equations
I also have ssreflect installed the same way, and I have no problems
importing ssreflect. I wonder what could be going wrong with Coq, or
perhaps it is a problem in the packaging of Equations?
Thanks a lot for your assistance.
-Ray
- [Coq-Club] Weird import problem?, Xuanrui Qi, 09/27/2018
- Re: [Coq-Club] Weird import problem?, Li-yao Xia, 09/27/2018
- Re: [Coq-Club] Weird import problem?, Xuanrui Qi, 09/27/2018
- Re: [Coq-Club] Weird import problem?, Anton Trunov, 09/27/2018
