- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Weird import problem?
- Date: Thu, 27 Sep 2018 14:26:41 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=xqi01 AT cs.tufts.edu; spf=None smtp.mailfrom=xqi01 AT cs.tufts.edu; spf=None smtp.helo=postmaster AT vm-delivery1.eecs.tufts.edu
- Ironport-phdr: 9a23:wQ3cwxxnWqZnw9PXCy+O+j09IxM/srCxBDY+r6Qd1OofIJqq85mqBkHD//Il1AaPAd2Eraocw8Pt8InYEVQa5piAtH1QOLdtbDQizfssogo7HcSeAlf6JvO5JwYzHcBFSUM3tyrjaRsdF8nxfUDdrWOv5jAOBBr/KRB1JuPoEYLOksi7ze+/94HRbglSmDaxfa55IQmrownWqsQYm5ZpJLwryhvOrHtIeuBWyn1tKFmOgRvy5dq+8YB6/ShItP0v68BPUaPhf6QlVrNYFygpM3o05MLwqxbOSxaE62YGXWUXlhpIBBXF7A3/U5zsvCb2qvZx1S+HNsDwULs6Wymt771zRRHrlSkJNyA3/m/Vhcx+kK1Urh2uqRNkzo7IYoyYLuZycr/HcN4YQ2dKQ8ZfVzZGAoO5d4YADvcBMvxer4nnulsOrAa1CxKtBOjyzTJJiWb23awm3+g8CgzJwBcgE8gSsHTJotX1KLwSXfqrw6bV0DXOdvVb0ir+5ojQah0tvP+BUa5qfcfQxkQjDR3Jg1uKpYHrPT6ZzuUAvmuB4+Z9Vu+iiHQrpgFwrzS1x8ohjJTCiJgPxVDe7yp5xZ44Jd2mR05/Zt6pCIVQtySDO4RrXMwiR2BouDgkxb0cuZ+3YTIGx4o5yBHDcPyLaZSI4g/tVOaNOjd0nmxqd6+ihxqq8EigzPPzVtWs3VpXoCdJjsPAu3EC2hDJ9MSKROFx80mj1DqX0gDc8OBEIUQ6larBLJ4hx6Y9l5UKsUTCAiP6hV77g7ONdkk+5uio9urnYqn9ppOGKYB7lxz+Prw0msOjGeQ4LhQOX2+D9Oug073j5FT1T6lOjv0riabUq4vaJMQepq6hGQBZyIcj6xClDzenytsUh3cHLEgWMC6A2oPuIhTFJO3yJfa5mVWl1jlxlN7cObi0MojEKGLekf/YfP4p+1ddkFMbxssZ+49aFqpHLf7uDByi/OfEBwM0ZlTni93sD89wg9tHCDC/R5SBOaaXimemo+cmIu2CfogQ4WqvIONj++PgkWR/lFMAL/HwgcknLUugF/EjGH23JGL2i45dQ2wR+BYjQvDxzlCOTGwLPivgb+cH/jg+TbmeI8LDS4Sq2u3TwiL+EpBSZ35LEEHVV3rlfJ7CR+oCdDnUL8N8wGQJ
Hello,
Thanks to Li-yao. This is right - the documentation needs to be
updated, I think!
Best,
Ray
On Thu, 2018-09-27 at 15:24 -0400, Li-yao Xia wrote:
> Hi Xuanrui,
> Try
> Require Import Equations.Equations.
> Looking at the "Print LoadPath" output, "Equations" is the path to
> the
> Equations library, but that is not a path to an actual file, which
> "Require" expects.
> The logical path "Equations.Equations" refers to the module
> .../user-contrib/Equations/Equations.vo which can thus be loaded.
> Li-yao
> On 9/27/18 3:17 PM, Xuanrui Qi wrote:
> > Hello all,
> > I appear to have run into a weird Import problem in Coq. I have
> > installed the "coq-equations" package using opam, but when I try to
> > Require Import the package:
> > Coq < Require Import Equations.
> > Toplevel input, characters 15-24:
> > Error: Unable to locate library Equations.
> > However, if I issue the "Print LoadPath." command, I can see that
> > Equations is in the load path!
> > Coq < Print LoadPath.
> > Logical Path / Physical path:
> > <> /home/xuanrui
> > <> /home/xuanrui/.opam/4.07.0/lib/coq/user-contrib
> > Equations /home/xuanrui/.opam/4.07.0/lib/coq/user-contrib/Equations
> > I also have ssreflect installed the same way, and I have no
> > problems
> > importing ssreflect. I wonder what could be going wrong with Coq,
> > or
> > perhaps it is a problem in the packaging of Equations?
> > Thanks a lot for your assistance.
> > -Ray
- [Coq-Club] Weird import problem?, Xuanrui Qi, 09/27/2018
- Re: [Coq-Club] Weird import problem?, Li-yao Xia, 09/27/2018
- Re: [Coq-Club] Weird import problem?, Xuanrui Qi, 09/27/2018
- Re: [Coq-Club] Weird import problem?, Anton Trunov, 09/27/2018
