- To: coq-club AT inria.fr
- Subject: [Coq-Club] Problems installing coq-flocq via opam
- Date: Tue, 6 Nov 2018 11:58:18 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=stevez AT cis.upenn.edu; spf=Pass smtp.mailfrom=stevez AT cis.upenn.edu; spf=None smtp.helo=postmaster AT mx0b-000c2a01.pphosted.com
- Ironport-phdr: 9a23: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
I am having difficulties installing coq-flocq via opam. I'm using opam 2.0.0 with ocaml 4.06.0 and coq 8.8.2 on OSX 10.14 (Mojave). The issue seems to be a permissions problem in the opam sandboxing script, which gives the error "# Failed to create server: Operation not permitted". The compilation of 'remake' generates a warning, but seems to succeed. (See detailed output below.)
I've tried disabling opam sandboxing (via 'opam init --disable-sandboxing'), but so far have had no luck. opam seems to work fine for other packages I've installed recently.
Any suggestions about where the problem might be?
Thanks!
--Steve
~ opam install -v coq-flocq
The following actions will be performed:
∗ install coq-flocq 3.0.0
<><> Gathering sources ><><><><><><><><><><><><><><><><><><><><><><><><><><> 🐫
[coq-flocq.3.0.0] found in cache
<><> Processing actions <><><><><><><><><><><><><><><><><><><><><><><><><><> 🐫
+ /Users/stevez/.opam/opam-init/hooks/sandbox.sh "build" "./configure" "--libdir" "/Users/stevez/.opam/4.06.0/lib/coq/user-contrib/Flocq" (CWD=/Users/stevez/.opam/4.06.0/.opam-switch/build/coq-flocq.3.0.0)
- checking for g++... g++
- checking whether the C++ compiler works... yes
- checking for C++ compiler default output file name... a.out
- checking for suffix of executables...
- checking whether we are cross compiling... no
- checking for suffix of object files... o
- checking whether we are using the GNU C++ compiler... yes
- checking whether g++ accepts -g... yes
- checking for coqc... /Users/stevez/.opam/4.06.0/bin/coqc
- checking for coqdep... /Users/stevez/.opam/4.06.0/bin/coqdep
- checking for coqdoc... /Users/stevez/.opam/4.06.0/bin/coqdoc
- configure: building remake...
- remake.cpp:2593:16: warning: 'tempnam' is deprecated: This function is provided for compatibility reasons only. Due to security concerns inherent in the design of tempnam(3), it is highly recommended that you use mkstemp(3) instead. [-Wdeprecated-declarations]
- socket_name = tempnam(NULL, "rmk-");
- /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.14.sdk/usr/include/stdio.h:306:1: note: 'tempnam' has been explicitly marked deprecated here
- __deprecated_msg("This function is provided for compatibility reasons only. Due to security concerns inherent in the design of tempnam(3), it is highly recommended that you use mkstemp(3) instead.")
- /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.14.sdk/usr/include/sys/cdefs.h:180:48: note: expanded from macro '__deprecated_msg'
- #define __deprecated_msg(_msg) __attribute__((deprecated(_msg)))
- 1 warning generated.
- configure: creating ./config.status
- config.status: creating Remakefile
- config.status: creating src/Version.v
+ /Users/stevez/.opam/opam-init/hooks/sandbox.sh "build" "./remake" "-j7" (CWD=/Users/stevez/.opam/4.06.0/.opam-switch/build/coq-flocq.3.0.0)
- Failed to create server: Operation not permitted
[ERROR] The compilation of coq-flocq failed at "/Users/stevez/.opam/opam-init/hooks/sandbox.sh build ./remake -j7".
#=== ERROR while compiling coq-flocq.3.0.0 ====================================#
# context 2.0.0 | macos/x86_64 | base-bigarray.base base-threads.base base-unix.base ocaml-base-compiler.4.06.0 | https://coq.inria.fr/opam/released
# path ~/.opam/4.06.0/.opam-switch/build/coq-flocq.3.0.0
# command ~/.opam/opam-init/hooks/sandbox.sh build ./remake -j7
# exit-code 1
# env-file ~/.opam/log/coq-flocq-1700-05296d.env
# output-file ~/.opam/log/coq-flocq-1700-05296d.out
### output ###
<><> Error report <><><><><><><><><><><><><><><><><><><><><><><><><><><><><> 🐫
┌─ The following actions failed
│ λ build coq-flocq 3.0.0
╶─ No changes have been performed
'opam install -v coq-flocq' failed.
- [Coq-Club] Problems installing coq-flocq via opam, Steve Zdancewic, 11/06/2018
- Re: [Coq-Club] Problems installing coq-flocq via opam, Guillaume Melquiond, 11/06/2018
- Re: [Coq-Club] Problems installing coq-flocq via opam, Steve Zdancewic, 11/06/2018
- Re: [Coq-Club] Problems installing coq-flocq via opam, Frédéric Blanqui, 11/07/2018
- Re: [Coq-Club] Problems installing coq-flocq via opam, Guillaume Melquiond, 11/07/2018
