- From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Problems installing coq-flocq via opam
- Date: Wed, 7 Nov 2018 08:18:20 +0100
Hello. I got the same problem with CoLoR but not with coq-bignums. See https://github.com/fblanqui/color/issues/12. Why do we have to disable sandboxing? Is it a bug in opam?
Le 06/11/2018 à 19:09, Guillaume Melquiond a écrit :
Le 06/11/2018 à 18:52, Steve Zdancewic a écrit :
Thanks! Manually removing ~/.opam/config to remove the wrap-*-command lines did the trick.
That is fortunate. Nonetheless, I will investigate what might cause remake to fail starting under the opam's sandbox on OSX.
Interestingly, I had previously tried to disable the sandbox by doing: opam init --reinit --disable-sandboxing. This caused all of my opam switch to be re-built, but had no effect (as far as I could tell) on the sandboxing scripts.
Right, this is a known feature of opam:
https://github.com/ocaml/opam/issues/3634
Best regards,
Guillaume
- [Coq-Club] Problems installing coq-flocq via opam, Steve Zdancewic, 11/06/2018
- Re: [Coq-Club] Problems installing coq-flocq via opam, Guillaume Melquiond, 11/06/2018
- Re: [Coq-Club] Problems installing coq-flocq via opam, Steve Zdancewic, 11/06/2018
- Re: [Coq-Club] Problems installing coq-flocq via opam, Frédéric Blanqui, 11/07/2018
- Re: [Coq-Club] Problems installing coq-flocq via opam, Guillaume Melquiond, 11/07/2018
