coq-club - Re: [Coq-Club] A question of encoding...
  • From: Pierre Casteran <pierre.casteran AT labri.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] A question of encoding...
  • Date: Mon, 3 Dec 2018 08:19:03 +0100 (CET)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=pierre.casteran AT labri.fr; spf=Pass smtp.mailfrom=pierre.casteran AT u-bordeaux.fr; spf=None smtp.helo=postmaster AT v-zimmta02.u-bordeaux.fr
  • Ironport-phdr: 9a23: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
Hi Fred,
In a former development on transition systems I used a predicate relating the
ends and intermediate steps of a path.
path : vertex -> list vertex -> vertex -> Prop
It is Ok wrt path concatenation and relation with transitive closures.
Hope this helps.
Pierre
----- Fred Smith
<fsmith1024 AT gmail.com>
a écrit :
> If I am not mistaken, that is exactly my definition pathS? It has the
> disadvantage as data that the path doesn't have a normal form; so strict
> equality (=) doesn't correspond directly to the desired semantic equality.
> One can always normalize before comparing, but it is exactly this kind of
> subtle tradeoff that puzzles me. Is it better to make the relation
> construction simple, but give up equality; or make the relation have a
> normal form by definition (pathI) and then write all kinds of convenience
> utilities to make this convenient. Both choices seem equally bad. I am
> concerned that in a few weeks I'll discover that one or the other is better
> for some very specific reason and end up having both versions with
> translations between them.
> -Fred
> On Sun, Dec 2, 2018 at 5:34 PM Jason -Zhong Sheng- Hu
> <fdhzs2010 AT hotmail.com>
> wrote:
> > Hi Fred,
> > yes, transitivity closure in Coq's standard library is defined to be a
> > proposition. But as I said, it doesn't prevent you from re-defining the
> > counter-part definition in Type, which gives you the full right to treat
> > it
> > as data and consequently extract a sequence of vertices along the path.
> > *Sincerely Yours, *
> > * Jason Hu*
> > *From:* Fred Smith
> > *Sent:* December 2, 2018 5:29 PM
> > *To:*
> > *Cc:*
> > *Subject:* Re: [Coq-Club] A question of encoding...
> > Hi Jason,
> > Thanks for the suggestion. Unfortunately, I need the actual paths as data
> > and not just the relation between endpoints of paths. If I understand
> > your
> > proposal correctly it would give me a relation (path v1 v2) which holds
> > whenever there exists a path between v1 and v2 without providing the
> > actual
> > path.
> > -Fred
> > On Sun, Dec 2, 2018 at 3:50 PM Jason -Zhong Sheng- Hu <
> > wrote:
> > Hi Fred,
> > I would try to avoid mentioning equality here. You need that because you
> > try to model an edge as a pair. Instead, I would model an edge to be a
> > binary relation and a path to be its transitivity closure:
> > Require Import Relations.
> > Section Graph.
> > Variable V : Type. (* type for vertices *)
> > Variable edge : relation V. (* a predicate if an edge exists between two
> > verices. *)
> > Definition path : relation V := clos_trans V edge.
> > End Graph.
> > It's close to your second choice but your second choice will probably lead
> > to some additional tedious proof steps, because pair in Coq doesn't have
> > definitional eta expansion.
> > If you need to inspect a path as data, I suppose you want to redefine
> > transitivity closure to be Set/Type. One advantage of defining data, is it
> > gives a structure for induction.
> > *Sincerely Yours, *
> > * Jason Hu*
> > *From:*
> > coq-club-request AT inria.fr
> > <coq-club-request AT inria.fr>
> > on behalf
> > of Fred Smith
> > *Sent:* December 2, 2018 3:25 PM
> > *To:*
> > *Subject:* [Coq-Club] A question of encoding...
> > Hi,
> > I am looking for engineering advice to help me understand the tradeoffs
> > between different ways of encoding the same information in Coq.
> > As my exercise, I am trying to encode paths in a graph. For simplicity
> > these are just lists of edges where each edge ends where the next edge
> > begins.
> > Below is a Coq file that uses 3 different encodings. Two inductive ones,
> > and the third as a predicate. What are the pros and cons of these
> > choices?
> > Thanks,
> > Fred
> > ----- path.v below -----
> > (* Experiments in encoding paths in Coq.
> > A path is simply a list of edges where the destination of the
> > preceding edge is the source of the next edge.
> > Require Import List.
> > Definition vertex := nat.
> > Definition edge := (vertex * vertex)%type.
> > (* Simple encoding as lists with a predicate *)
> > Fixpoint path (l : list edge) :=
> > match l with
> > | nil => False
> > | hd :: tl => (match tl with
> > | nil => True
> > | hd2 :: tl2 => (snd hd) = (fst hd2)
> > end) /\ (path tl)
> > end.
> > (* Define as a subset. *)
> > Definition Path := { l : list edge | path l }.
> > (* Encode as an inductive definition that makes the path correct by
> > construction. Note, need to include the vertex endpoints in the type
> > to enforce the invariants. *)
> > Inductive pathI : vertex -> vertex -> Set :=
> > | path_tl : forall e:edge, pathI (fst e) (snd e)
> > | path_hd : forall e:edge, forall v1 v2:vertex, forall p:pathI v1 v2, (snd
> > e) = v1 -> pathI (fst e) v2.
> > (* We could write a symmetrical encoding as well. *)
> > Inductive pathS : vertex -> vertex -> Set :=
> > | pathS_edge : forall e:edge, pathS (fst e) (snd e)
> > | pathS_compose : forall v1 v2 v3 : vertex, forall p1 : pathS v1 v2,
> > forall p2 : pathS v2 v3, pathS v1 v3.
> > (* Which of these encoding is preferred?
> > 1. Predicate encoding allows reuse of list facts and definitions, but
> > requires lemmas connecting them together.
> > 2. Inductive encoding requires reimplmenting all list elements.
> > 3. Symmetric encoding makes simple equality not work, requires a special
> > equality operator.
