- To: Fred Smith <fsmith1024 AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] A question of encoding...
- Date: Mon, 03 Dec 2018 11:52:20 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=e AT x80.org; spf=Pass smtp.mailfrom=e AT x80.org; spf=Pass smtp.helo=postmaster AT x80.org
- Ironport-phdr: 9a23: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
- Organization: X80 Heavy Industries
Hi Fred,
Fred Smith
writes:
> I am looking for engineering advice to help me understand the tradeoffs
> between different ways of encoding the same information in Coq.
> As my exercise, I am trying to encode paths in a graph. For simplicity
> these are just lists of edges where each edge ends where the next edge
> begins.
> Below is a Coq file that uses 3 different encodings. Two inductive ones,
> and the third as a predicate. What are the pros and cons of these choices?
You may also be interested in the math-comp's definition of path:
Fixpoint path T (e : rel T) x (p : seq T) :=
if p is y :: p' then e x y && path y p' else true.
Actually there are some talks by George Gonthier where [IRRC] he
discussed the different tradeoffs among the different ways of encoding
paths [I'm afraid you'll have to google for the exact video link]
Cheers,
E.
- [Coq-Club] A question of encoding..., Fred Smith, 12/02/2018
- Re: [Coq-Club] A question of encoding..., Jason -Zhong Sheng- Hu, 12/02/2018
- Re: [Coq-Club] A question of encoding..., Fred Smith, 12/02/2018
- Re: [Coq-Club] A question of encoding..., Pierre Casteran, 12/03/2018
- Re: [Coq-Club] A question of encoding..., Emilio Jesús Gallego Arias, 12/03/2018
- Re: [Coq-Club] A question of encoding..., Fred Smith, 12/05/2018
- Re: [Coq-Club] A question of encoding..., Christian Doczkal, 12/03/2018
- Re: [Coq-Club] A question of encoding..., Xuanrui Qi, 12/03/2018
