Re: [Coq-Club] Question on Coq-Interval: i_bisect_diff x vs. i_bisect taylor x 1
- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Question on Coq-Interval: i_bisect_diff x vs. i_bisect taylor x 1
- Date: Thu, 17 Jan 2019 15:50:12 +0100
Le 17/01/2019 à 10:12, Soegtrop, Michael a écrit :
There is one thing I don’t understand, though.: i_bisect_taylor and i_bisect work as expected, but I don’t understand what i_bisect_diff does. I would expect that the results of i_bisect_diff is similar to i_bisect_taylor x 1, since both should take 1^st derivative information into account – maybe in a slightly different way. But to my surprise i_bisect_diff gives in all cases I tried the same result as i_bisect, which is far away from i_bisect_taylor x 1. Below is a simple example, which also shows the error bounds I get. Could you please explain this behavior?
My guess is that i_bisect_diff is getting confused by the absolute value. If you remove it, the bounds should get much closer to the ones from i_bisect_taylor.
More precisely, i_bisect_diff takes into account the first derivative only at the end, once it knows that the function is differentiable according to the intervals computed by naive interval arithmetic. Since the interval passed to the absolute value contains zero (I guess), the first derivative is discarded. As for i_bisect_taylor, it takes the derivatives into account right from the start, so, by the time the absolute value has an adverse effect on differentiability, the bounds are already tight enough.
I have one more question: I guess my Coq skill is slightly rusted: how can I supply the term “t” to the tactic in the below example?
The following is a bit verbose but it should help:
match goal with
| t := ?f |- _ => interval_intro f with ...
end
Best regards,
Guillaume
- [Coq-Club] Question on Coq-Interval: i_bisect_diff x vs. i_bisect taylor x 1, Soegtrop, Michael, 01/17/2019
- Re: [Coq-Club] Question on Coq-Interval: i_bisect_diff x vs. i_bisect taylor x 1, Guillaume Melquiond, 01/17/2019
- RE: [Coq-Club] Question on Coq-Interval: i_bisect_diff x vs. i_bisect taylor x 1, Soegtrop, Michael, 01/17/2019
