Re: [Coq-Club] Question on Coq-Interval: i_bisect_diff x vs. i_bisect taylor x 1
- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Question on Coq-Interval: i_bisect_diff x vs. i_bisect taylor x 1
- Date: Thu, 17 Jan 2019 18:06:57 +0100
Le 17/01/2019 à 17:42, Soegtrop, Michael a écrit :
Dear Guillaume,
My guess is that i_bisect_diff is getting confused by the absolute value. If
you
remove it, the bounds should get much closer to the ones from i_bisect_taylor.
Thanks for the explanation! I guess the best option is then to use
i_bisect_taylor x 1 instead of i_bisect_diff.
Actually, the best option is to use "i_bisect_taylor x 3" (or more) since you have a degree-3 polynomial in your expression. That way, no information from this polynomial is lost an no bisection is needed. Even "i_depth 1" would give a tight bound in that case, theoretically.
Keep in mind that the bisection depth potentially causes an exponential increase in time, while the approximation degree causes only a polynomial increase in time. That said, your examples are sufficiently simple so that the time complexity does not matter.
Removing Rabs does lead to the expected result (i_bisect_taylor is better by
about a factor of 3 or 4 than i_bisect_diff, but i_bisect_diff is much better
than i_bisect). What does not work is keeping Rabs and changing the x range
such that the term inside of Rabs does not change the sign - i_bisect_diff
and i_bisect are still the same then.
You are trying to compute an enclosure of "abs(f - g)" with g approximating f (I guess). So, if g is a good approximation of f, then the interval image of "f - g" almost always crosses zero, due to the dependency effect of interval arithmetic. Thus, except for minuscule ranges of x, the tactic will never be able to use the first derivative.
Best regards,
Guillaume
- [Coq-Club] Question on Coq-Interval: i_bisect_diff x vs. i_bisect taylor x 1, Soegtrop, Michael, 01/17/2019
- Re: [Coq-Club] Question on Coq-Interval: i_bisect_diff x vs. i_bisect taylor x 1, Guillaume Melquiond, 01/17/2019
- RE: [Coq-Club] Question on Coq-Interval: i_bisect_diff x vs. i_bisect taylor x 1, Soegtrop, Michael, 01/17/2019
