coq-club - Re: [Coq-Club] Coq Ocaml version
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Coq Ocaml version
  • Date: Fri, 15 Mar 2019 09:54:35 -0700
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=itz AT very.loosely.org; spf=Pass smtp.mailfrom=itz AT very.loosely.org; spf=Pass smtp.helo=postmaster AT very.loosely.org
  • Ironport-phdr: 9a23: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
On 2019-03-15 11:00, Théo Zimmermann wrote:
> That's a good point. This is something you can pass as argument to
> configure when building Coq from sources, but not when using opam.
> Emilio, if this is the default recommended flambda-opts value, why not
> put this as the default? Or does it have an impact when building
> without flambda? If that's not the case, the opam package could be
> changed to use this configure flag.
Up the thread someone wrote:
Some1> But beware that this configuration can make compiling Coq consume
Some1> a lot of memory (on my machine, up to 15G). If you don't have a
Some1> lot of memory, compilation will fail.
If _this_ is true, I definitely cannot afford to use these options.
Please do not change the default unless there is a way to override it.
Please don't Cc: me privately on mailing lists and Usenet,
if you also post the followup to the list or newsgroup.
To reply privately _only_ on Usenet and on broken lists
which rewrite From, fetch the TXT record for no-use.mooo.com.
