- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Coq Ocaml version
- Date: Fri, 15 Mar 2019 18:20:44 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=theo.zimmi AT gmail.com; spf=Pass smtp.mailfrom=theo.zimmi AT gmail.com; spf=None smtp.helo=postmaster AT mail-vs1-f51.google.com
- Ironport-phdr: 9a23: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
"This configuration" includes the use of the OCaml flambda compiler.
My point was that, in case the flambda compiler is not used, the
options are (probably, but this needs to be confirmed) harmless. In
this case, there is no problem in changing the default value of these
options, as it only affects the users of the flambda compiler.
Le ven. 15 mars 2019 à 17:56, Ian
<itz AT very.loosely.org>
a écrit :
> On 2019-03-15 11:00, Théo Zimmermann wrote:
> > That's a good point. This is something you can pass as argument to
> > configure when building Coq from sources, but not when using opam.
> > Emilio, if this is the default recommended flambda-opts value, why not
> > put this as the default? Or does it have an impact when building
> > without flambda? If that's not the case, the opam package could be
> > changed to use this configure flag.
> Up the thread someone wrote:
> Some1> But beware that this configuration can make compiling Coq consume
> Some1> a lot of memory (on my machine, up to 15G). If you don't have a
> Some1> lot of memory, compilation will fail.
> If _this_ is true, I definitely cannot afford to use these options.
> Please do not change the default unless there is a way to override it.
> Please don't Cc: me privately on mailing lists and Usenet,
> if you also post the followup to the list or newsgroup.
> To reply privately _only_ on Usenet and on broken lists
> which rewrite From, fetch the TXT record for no-use.mooo.com.
- Re: [Coq-Club] Implementation of Coq's automation tactics, (continued)
- Re: [Coq-Club] Implementation of Coq's automation tactics, Joomy Korkut, 03/08/2019
- Re: [Coq-Club] Implementation of Coq's automation tactics, Gaëtan Gilbert, 03/08/2019
- [Coq-Club] Coq Ocaml version, Laurent Thery, 03/14/2019
- Re: [Coq-Club] Coq Ocaml version, CYRIL SIX, 03/14/2019
- Re: [Coq-Club] Coq Ocaml version, Emilio Jesús Gallego Arias, 03/14/2019
- Re: [Coq-Club] Coq Ocaml version, Xuanrui Qi, 03/14/2019
- Re: [Coq-Club] Coq Ocaml version, Laurent Thery, 03/15/2019
- Re: [Coq-Club] Coq Ocaml version, Théo Zimmermann, 03/15/2019
- Re: [Coq-Club] Coq Ocaml version, Gaëtan Gilbert, 03/15/2019
- Re: [Coq-Club] Coq Ocaml version, Ian, 03/15/2019
- Re: [Coq-Club] Coq Ocaml version, Emilio Jesús Gallego Arias, 03/15/2019
- Re: [Coq-Club] Coq Ocaml version, Laurent Thery, 03/16/2019
