- From: Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] "exists" Extraction
- Date: Thu, 11 Apr 2019 09:47:20 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT skyskimmer.net; spf=Pass smtp.mailfrom=gaetan.gilbert AT skyskimmer.net; spf=None smtp.helo=postmaster AT relay12.mail.gandi.net
- Ironport-phdr: 9a23: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
forall isn't Prop specific
replace /\ by + (needs type scope)
Also it may be that you can keep [valid] in Prop, only doing
Definition provable (A : formula) :=
{ t : ftree | ftree_formula t = A /\ valid t }.
( { x : T | P } is notation for sig )
See proj1_sig and proj2_sig for how to get information out of it.
Gaëtan Gilbert
On 11/04/2019 09:41, Morgan Sinclaire wrote:
Thank you for that information! However, that still doesn't settle /how/ to convert a given Prop into Type. I have little idea how to do this since I've never done anything nontrivial with Type. For instance, my current definition has Prop-specific syntax like "forall" and "/\" and I wouldn't know what their equivalents in Type would be. Is there a good reference for this?
On Thu, Apr 11, 2019 at 12:09 AM Théo Zimmermann <theo.zimmi AT gmail.com <mailto:theo.zimmi AT gmail.com>> wrote:
Hi,
Having an undecidable predicate certainly rules out expressing it in
bool, but it does not rule out expressing it in Type. There are two
differences between Prop and Type: impredicative Prop vs predicate
Type hierarchy and the erasable status of Prop vs the extractable
status of Type (and BTW the fact that Coq used to have an extractable
impredicative sort Set shows that the two questions are separate:
https://coq.inria.fr/refman/language/cic.html#the-calculus-of-inductive-constructions-with-impredicative-set).
The decidability of a proposition hasn't anything to do with this. If
you define a predicate in Type, it is not more decidable than if you
define it in Prop. The difference is that if you are able to prove
that an element is in your predicate in Type, then you can extract a
computation from this proof (not the same thing, as this is not
generic but for a single element).
Thëo
Le jeu. 11 avr. 2019 à 07:33, Morgan Sinclaire
<morgansinclaire AT boisestate.edu
<mailto:morgansinclaire AT boisestate.edu>>
a écrit :
> Thank you for the responses, but I want to emphasize again that
my predicate "valid" is not decidable, otherwise I could've just
made it boolean in the first place. I think that rules out Sigma
types, but I'd like to be wrong about that. I am glad I know about
ConstructiveGroundEpsilon now, and that certainly looks close to
what I need, but if the "P : A -> Prop" is supposed to be be my
"valid" predicate, then that also won't work because it's not
undecidable.
> Here is my current code for full details, the relevant stuff
starts on line 3643. Let me try to explain my situation a little bit
more fully (but without going into all the weeds):
> I have a data structure called ftree ("formula tree") which
consists of infinitely branching trees decorated with formulas. The
definition has 19 constructors corresponding to the rules of
inference in this system, and looks like:
>> Inductive ftree : Type :=
>> | node : formula -> ftree (* axiom *)
>> | w_rule_a : formula -> nat -> (nat -> ftree) -> ftree
> It is infinitely branching because of w_rule_a. What I'm trying
to do is represent proofs in a certain infinitary logic, so the
infinite branching is there intentionally. I can decidably extract
the formula at the root of an ftree (the conclusion of a proof):
>> Fixpoint ftree_formula (P : ftree) : formula :=
>> match P with
>> | node A => A
>> | w_rule_a A n g => univ n A
> Where "univ n A" denotes the formula "forall x_n, A". I say that
an a given ftree P is valid iff it actually represents a proof in
this infinitary system:
>> Fixpoint valid (P : ftree) : Prop :=
>> match P with
>> | node A => PA_omega_axiom A = true
>> | w_rule_a A n g => forall (m : nat),
>> ftree_formula (g m) = substitution A n (represent m) /\
valid (g m)
> Where "substitution A n (represent m)" denotes the formula
"A[m/x_n]", so the w_rule_a means that if we have a function g: nat
-> ftree such that for every m, (g m) is a proof of A(m), then we
can infer forall x_n A(x_n).
> So in this infinitary system, it is not decidable to determine if
a given ftree is valid, since that would require reasoning about the
halting of any given g.
> Finally, I define the predicate on formulas:
>> Definition provable (A : formula) : Prop :=
>> exists (t : ftree), ftree_formula t = A /\ valid t.
> Now I'm trying to prove a technical lemma that involves inducting
over ftree, and the place I'm stuck is:
>> A : formula
>> n : nat
>> H : forall m : nat,
>> exists t : ftree, ftree_formula t = substitution A n
(represent m) /\ valid t
>> ______________________________________(1/1)
>> exists t : ftree, ftree_formula t = univ n A /\ valid t
> So to prove the goal, I need to use "w_rule_a", which means I
need a function g: nat -> ftree satisfying the required properties.
By Curry-Howard, that function should be H itself, but this doesn't
seem to work because I (apparently) can't extract the needed
computational content from H.
> So is it completely hopeless since valid is undecidable in
general? I feel like what I'm trying to do makes sense if one takes
Curry-Howard literally, and if so there should be some workaround.
> P.S. One other thing I tried was defining "provable" instead as a
sig:
>> Definition provable (A : formula) : Type :=
>> {t : ftree | ftree_formula t = A /\ valid t}.
> But then the induction setup I'm using to prove this lemma
totally breaks, with the error:
>> Cannot find the elimination combinator PA_omega_theorem_rec, the
elimination of the inductive definition PA_omega_theorem on sort Set
is probably not allowed.
> I don't think I can avoid that, but if this is the recommended
route, I'll probably have to give more details about this lemma.
> On Wed, Apr 10, 2019 at 7:01 PM mukesh tiwari
<mukeshtiwari.iiitm AT gmail.com
<mailto:mukeshtiwari.iiitm AT gmail.com>>
wrote:
>> Hi Morgan,
>> I am not Coq expert, so take my answer with grain of salt. For
your first question, you can have a look at constructiveEpsilon[1]
library, specially ConstructiveGroundEpsilon.
>> Variable A : Type.
>> Variable f : A -> nat.
>> Variable g : nat -> A.
>> Hypothesis gof_eq_id : forall x : A, g (f x) = x.
>> Variable P : A -> Prop.
>> Hypothesis P_decidable : forall x : A, {P x} + {~ P x}.
>> Definition P' (x : nat) : Prop := P (g x).
>> Lemma P'_decidable : forall n : nat, {P' n} + {~ P' n}.
>> Lemma constructive_indefinite_ground_description : (exists x :
A, P x) -> {x : A | P x}.
>> If you can show one to one correspondence with nat and your type
ftree with proof of gof_eq_id and P_decidable, then using
constructive_indefinite_ground_description you can turn (exists x :
A, P x) to {x : A | P x} (computational content) which is probably
you are looking for.
>> I don't have any precise answer for your second question, but
have a look at Arthur's answer about Prop and bool [2]. If you can
turn your connectives in Fixpoint valid (P : ftree) : Prop := ... in
such a way that it returns bool then you would have function which
computes. Also, feel free to share your code.
>> Best,
>> Mukesh
>> On Thu, Apr 11, 2019 at 7:31 AM Morgan Sinclaire
wrote:
>>> I'm having trouble with extracting information from Prop, and
specifically with the Prop/Type and ex/sig distinction which I
wasn't aware of before. What I have is this definition:
>>> Where "ftree" is a certain infinitely-branching tree structure
I've defined, and for this reason "valid" is undecidable in general.
>>> Now I'm in the middle of a proof, where I have a hypothesis
that looks like:
>>>> H : forall m : nat, exists t : ftree, valid t /\ [stuff about t]
>>> And to complete my proof I need to produce a function of the form:
>>>> nat -> ftree
>>> And by Curry-Howard, H should be such a function, but Coq
doesn't believe so, because I can't extract computational
information from "exists" (as discussed here, section 12.2).
>>> Now, I know Coq does this because it wants to limit the amount
of program extraction one can do, but in my case I want full
Curry-Howard. So my first question is:
>>> 1) Can I "toggle" this feature in Coq so I can get full program
extraction from "exists"?
>>> If not, I don't know much about Sigma types, but I don't think
I can just convert this "ex" into "sig" since the predicate "valid"
is undecidable? I haven't worked with Type at all, so my other question:
>>> 2) Is there an easy way to convert a Prop to a Type?
>>> If so, I can change my definition of "valid" to be of type
Type. Currently that definition is 63 lines and involves some Prop
syntax such as "forall" and "/\", so any reference on how to do that
in Type would be helpful so I can understand what I'm doing.
>>> Thanks!
>> [1] https://coq.inria.fr/library/Coq.Logic.ConstructiveEpsilon.html
>> [2]
https://stackoverflow.com/questions/31554453/why-are-logical-connectives-and-booleans-separate-in-coq/31568076#31568076
- [Coq-Club] "exists" Extraction, Morgan Sinclaire, 04/10/2019
- Re: [Coq-Club] "exists" Extraction, Helmut Brandl, 04/10/2019
- Re: [Coq-Club] "exists" Extraction, Jason -Zhong Sheng- Hu, 04/11/2019
- Re: [Coq-Club] "exists" Extraction, mukesh tiwari, 04/11/2019
- Re: [Coq-Club] "exists" Extraction, Morgan Sinclaire, 04/11/2019
- Re: [Coq-Club] "exists" Extraction, Théo Zimmermann, 04/11/2019
- Re: [Coq-Club] "exists" Extraction, Gaëtan Gilbert, 04/11/2019
- Re: [Coq-Club] "exists" Extraction, Sylvain Boulmé, 04/11/2019
- Re: [Coq-Club] "exists" Extraction, Dominique Larchey-Wendling, 04/11/2019
