coq-club - Re: [Coq-Club] "exists" Extraction
  • From: Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] "exists" Extraction
  • Date: Thu, 11 Apr 2019 11:01:39 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT skyskimmer.net; spf=Pass smtp.mailfrom=gaetan.gilbert AT skyskimmer.net; spf=None smtp.helo=postmaster AT relay3-d.mail.gandi.net
  • Ironport-phdr: 9a23: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
> replace /\ by + (needs type scope)
this was of course incorrect, /\ is like *
Gaëtan Gilbert
On 11/04/2019 09:47, Gaëtan Gilbert wrote:
forall isn't Prop specific
Also it may be that you can keep [valid] in Prop, only doing
    Definition provable (A : formula) :=
      { t : ftree | ftree_formula t = A /\ valid t }.
( { x : T | P } is notation for sig )
See proj1_sig and proj2_sig for how to get information out of it.
Gaëtan Gilbert
On 11/04/2019 09:41, Morgan Sinclaire wrote:
Thank you for that information! However, that still doesn't settle /how/ to convert a given Prop into Type. I have little idea how to do this since I've never done anything nontrivial with Type. For instance, my current definition has Prop-specific syntax like "forall" and "/\" and I wouldn't know what their equivalents in Type would be. Is there a good reference for this?
On Thu, Apr 11, 2019 at 12:09 AM Théo Zimmermann <theo.zimmi AT gmail.com <mailto:theo.zimmi AT gmail.com>> wrote:
    Hi,
    Having an undecidable predicate certainly rules out expressing it in
    bool, but it does not rule out expressing it in Type. There are two
    differences between Prop and Type: impredicative Prop vs predicate
    Type hierarchy and the erasable status of Prop vs the extractable
    status of Type (and BTW the fact that Coq used to have an extractable
    impredicative sort Set shows that the two questions are separate:
https://coq.inria.fr/refman/language/cic.html#the-calculus-of-inductive-constructions-with-impredicative-set).
    The decidability of a proposition hasn't anything to do with this. If
    you define a predicate in Type, it is not more decidable than if you
    define it in Prop. The difference is that if you are able to prove
    that an element is in your predicate in Type, then you can extract a
    computation from this proof (not the same thing, as this is not
    generic but for a single element).
    Thëo
    Le jeu. 11 avr. 2019 à 07:33, Morgan Sinclaire
<morgansinclaire AT boisestate.edu
<mailto:morgansinclaire AT boisestate.edu>>
a écrit :
     > Thank you for the responses, but I want to emphasize again that
    my predicate "valid" is not decidable, otherwise I could've just
    made it boolean in the first place. I think that rules out Sigma
    types, but I'd like to be wrong about that. I am glad I know about
    ConstructiveGroundEpsilon now, and that certainly looks close to
    what I need, but if the "P : A -> Prop" is supposed to be be my
    "valid" predicate, then that also won't work because it's not
    undecidable.
     > Here is my current code for full details, the relevant stuff
    starts on line 3643. Let me try to explain my situation a little bit
    more fully (but without going into all the weeds):
     > I have a data structure called ftree ("formula tree") which
    consists of infinitely branching trees decorated with formulas. The
    definition has 19 constructors corresponding to the rules of
    inference in this system, and looks like:
     >> Inductive ftree : Type :=
     >> | node : formula -> ftree            (* axiom *)
     >> | w_rule_a : formula -> nat -> (nat -> ftree) -> ftree
     > It is infinitely branching because of w_rule_a. What I'm trying
    to do is represent proofs in a certain infinitary logic, so the
    infinite branching is there intentionally. I can decidably extract
    the formula at the root of an ftree (the conclusion of a proof):
     >> Fixpoint ftree_formula (P : ftree) : formula :=
     >> match P with
     >> | node A => A
     >> | w_rule_a A n g => univ n A
     > Where "univ n A" denotes the formula "forall x_n, A". I say that
    an a given ftree P is valid iff it actually represents a proof in
    this infinitary system:
     >> Fixpoint valid (P : ftree) : Prop :=
     >> match P with
     >> | node A => PA_omega_axiom A = true
     >> | w_rule_a A n g => forall (m : nat),
     >>     ftree_formula (g m) = substitution A n (represent m) /\
    valid (g m)
     > Where "substitution A n (represent m)" denotes the formula
    "A[m/x_n]", so the w_rule_a means that if we have a function g: nat
    -> ftree such that for every m, (g m) is a proof of A(m), then we
    can infer forall x_n A(x_n).
     > So in this infinitary system, it is not decidable to determine if
    a given ftree is valid, since that would require reasoning about the
    halting of any given g.
     > Finally, I define the predicate on formulas:
     >> Definition provable (A : formula) : Prop :=
     >>   exists (t : ftree), ftree_formula t = A /\ valid t.
     > Now I'm trying to prove a technical lemma that involves inducting
    over ftree, and the place I'm stuck is:
     >> A : formula
     >> n : nat
     >> H : forall m : nat,
     >>     exists t : ftree, ftree_formula t = substitution A n
    (represent m) /\ valid t
     >> ______________________________________(1/1)
     >> exists t : ftree, ftree_formula t = univ n A /\ valid t
     > So to prove the goal, I need to use "w_rule_a", which means I
    need a function g: nat -> ftree satisfying the required properties.
    By Curry-Howard, that function should be H itself, but this doesn't
    seem to work because I (apparently) can't extract the needed
    computational content from H.
     > So is it completely hopeless since valid is undecidable in
    general? I feel like what I'm trying to do makes sense if one takes
    Curry-Howard literally, and if so there should be some workaround.
     > P.S. One other thing I tried was defining "provable" instead as a
    sig:
     >> Definition provable (A : formula) : Type :=
     >>   {t : ftree | ftree_formula t = A /\ valid t}.
     > But then the induction setup I'm using to prove this lemma
    totally breaks, with the error:
     >> Cannot find the elimination combinator PA_omega_theorem_rec, the
    elimination of the inductive definition PA_omega_theorem on sort Set
    is probably not allowed.
     > I don't think I can avoid that, but if this is the recommended
    route, I'll probably have to give more details about this lemma.
     > On Wed, Apr 10, 2019 at 7:01 PM mukesh tiwari
<mukeshtiwari.iiitm AT gmail.com
<mailto:mukeshtiwari.iiitm AT gmail.com>>
    wrote:
     >> Hi Morgan,
     >> I am not Coq expert, so take my answer with grain of salt.  For
    your first question, you can have a look at constructiveEpsilon[1]
    library, specially  ConstructiveGroundEpsilon.
     >> Variable A : Type.
     >> Variable f : A -> nat.
     >> Variable g : nat -> A.
     >> Hypothesis gof_eq_id : forall x : A, g (f x) = x.
     >> Variable P : A -> Prop.
     >> Hypothesis P_decidable : forall x : A, {P x} + {~ P x}.
     >> Definition P' (x : nat) : Prop := P (g x).
     >> Lemma P'_decidable : forall n : nat, {P' n} + {~ P' n}.
     >> Lemma constructive_indefinite_ground_description : (exists x :
    A, P x) -> {x : A | P x}.
     >> If you can show one to one correspondence with nat and your type
    ftree with proof of gof_eq_id and  P_decidable, then using
    constructive_indefinite_ground_description you can turn (exists x :
    A, P x) to {x : A | P x} (computational content) which is probably
    you are looking for.
     >> I don't have any precise answer for your second question, but
    have a look at Arthur's answer about Prop and bool [2]. If you can
    turn your connectives in Fixpoint valid (P : ftree) : Prop := ... in
    such a way that it returns bool then you would have function which
    computes.  Also, feel free to share your code.
     >> Best,
     >> Mukesh
     >> On Thu, Apr 11, 2019 at 7:31 AM Morgan Sinclaire
wrote:
     >>> I'm having trouble with extracting information from Prop, and
    specifically with the Prop/Type and ex/sig distinction which I
    wasn't aware of before. What I have is this definition:
     >>>> Fixpoint valid (P : ftree) : Prop := ...
     >>> Where "ftree" is a certain infinitely-branching tree structure
    I've defined, and for this reason "valid" is undecidable in general.
     >>> Now I'm in the middle of a proof, where I have a hypothesis
    that looks like:
     >>>> H : forall m : nat, exists t : ftree, valid t /\ [stuff about t]
     >>> And to complete my proof I need to produce a function of the form:
     >>>> nat -> ftree
     >>> And by Curry-Howard, H should be such a function, but Coq
    doesn't believe so, because I can't extract computational
    information from "exists" (as discussed here, section 12.2).
     >>> Now, I know Coq does this because it wants to limit the amount
    of program extraction one can do, but in my case I want full
    Curry-Howard. So my first question is:
     >>> 1) Can I "toggle" this feature in Coq so I can get full program
    extraction from "exists"?
     >>> If not, I don't know much about Sigma types, but I don't think
    I can just convert this "ex" into "sig" since the predicate "valid"
    is undecidable? I haven't worked with Type at all, so my other question:
     >>> 2) Is there an easy way to convert a Prop to a Type?
     >>> If so, I can change my definition of "valid" to be of type
    Type. Currently that definition is 63 lines and involves some Prop
    syntax such as "forall" and "/\", so any reference on how to do that
    in Type would be helpful so I can understand what I'm doing.
     >>> Thanks!
     >> [1] https://coq.inria.fr/library/Coq.Logic.ConstructiveEpsilon.html
     >> [2]
https://stackoverflow.com/questions/31554453/why-are-logical-connectives-and-booleans-separate-in-coq/31568076#31568076
