- From: Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Something wrong with the coq-released OPAM repo?
- Date: Thu, 30 May 2019 21:01:46 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT skyskimmer.net; spf=Pass smtp.mailfrom=gaetan.gilbert AT skyskimmer.net; spf=None smtp.helo=postmaster AT relay5-d.mail.gandi.net
- Ironport-phdr: 9a23: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
I mean the "opam repo" command
Gaëtan Gilbert
On 30/05/2019 20:56, Xuanrui Qi wrote:
I'm using opam 2.0.4. I'm not sure what you mean by "what does the repo
say", but if I `ls .opam/repo/coq-released/packages/coq-mathcomp-
ssreflect/` then the only versions that come up are:
coq-mathcomp-ssreflect.1.6 coq-mathcomp-ssreflect.1.6.2 coq-
mathcomp-ssreflect.1.7.0
coq-mathcomp-ssreflect.1.6.1 coq-mathcomp-ssreflect.1.6.4 coq-
mathcomp-ssreflect.1.8.0
Trying `opam update` multiple times did not help.
Xuanrui
On Thu, 2019-05-30 at 11:33 +0200, Gaëtan Gilbert wrote:
What's your opam version? What does opam repo say?
Gaëtan Gilbert
On 30/05/2019 11:30, Xuanrui Qi wrote:
Hello all,
When I browse the coq-released OPAM repo in a browser, I see that
the
latest version of coq-mathcomp-ssreflect is 1.9.0 (
https://coq.inria.fr/opam/released/packages/coq-mathcomp-ssreflect/coq-mathcomp-ssreflect.1.9.0/opam
). However, when I do:
opam update
opam install coq-mathcomp-ssreflect
It installs v1.8.0 of the package. I've tried specifying version
1.9.0,
but it just complains that:
[ERROR] Package coq-mathcomp-ssreflect has no version 1.9.0.
When I go into ~/.opam/repo/coq-released/packages/coq-mathcomp-
ssreflect, I see there's indeed no 1.8.0. Re-running `opam update`
or
purging and re-adding the repo doesn't help. There seems to be some
sort of inconsistency there.
Is anyone experiencing the same problem at the moment?
-Xuanrui
- [Coq-Club] Something wrong with the coq-released OPAM repo?, Xuanrui Qi, 05/30/2019
- Re: [Coq-Club] Something wrong with the coq-released OPAM repo?, Gaëtan Gilbert, 05/30/2019
- Re: [Coq-Club] Something wrong with the coq-released OPAM repo?, Xuanrui Qi, 05/30/2019
- Re: [Coq-Club] Something wrong with the coq-released OPAM repo?, Matthieu Sozeau, 05/30/2019
