- From: Matthieu Sozeau <matthieu.sozeau AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Something wrong with the coq-released OPAM repo?
- Date: Thu, 30 May 2019 21:05:37 +0200
Hi,
The issue is known, is server-side and its resolution can be tracked here: https://github.com/coq/opam-coq-archive/issues/730#issuecomment-497441656
Best,
Best,
-- Matthieu
I mean the "opam repo" command
Gaëtan Gilbert
On 30/05/2019 20:56, Xuanrui Qi wrote:I'm using opam 2.0.4. I'm not sure what you mean by "what does the reposay", but if I `ls .opam/repo/coq-released/packages/coq-mathcomp-ssreflect/` then the only versions that come up are:coq-mathcomp-ssreflect.1.6 coq-mathcomp-ssreflect.1.6.2 coq-mathcomp-ssreflect.1.7.0coq-mathcomp-ssreflect.1.6.1 coq-mathcomp-ssreflect.1.6.4 coq-mathcomp-ssreflect.1.8.0Trying `opam update` multiple times did not help.XuanruiOn Thu, 2019-05-30 at 11:33 +0200, Gaëtan Gilbert wrote:What's your opam version? What does opam repo say?Gaëtan GilbertOn 30/05/2019 11:30, Xuanrui Qi wrote:Hello all,When I browse the coq-released OPAM repo in a browser, I see thatthelatest version of coq-mathcomp-ssreflect is 1.9.0 (https://coq.inria.fr/opam/released/packages/coq-mathcomp-ssreflect/coq-mathcomp-ssreflect.1.9.0/opam). However, when I do:opam updateopam install coq-mathcomp-ssreflectIt installs v1.8.0 of the package. I've tried specifying version1.9.0,but it just complains that:[ERROR] Package coq-mathcomp-ssreflect has no version 1.9.0.When I go into ~/.opam/repo/coq-released/packages/coq-mathcomp-ssreflect, I see there's indeed no 1.8.0. Re-running `opam update`orpurging and re-adding the repo doesn't help. There seems to be somesort of inconsistency there.Is anyone experiencing the same problem at the moment?-Xuanrui
- [Coq-Club] Something wrong with the coq-released OPAM repo?, Xuanrui Qi, 05/30/2019
- Re: [Coq-Club] Something wrong with the coq-released OPAM repo?, Gaëtan Gilbert, 05/30/2019
- Re: [Coq-Club] Something wrong with the coq-released OPAM repo?, Xuanrui Qi, 05/30/2019
- Re: [Coq-Club] Something wrong with the coq-released OPAM repo?, Matthieu Sozeau, 05/30/2019
