- From: richard dapoigny <richard.dapoigny AT univ-smb.fr>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Singleton with sets as characteristic functions in classical logic
- Date: Tue, 27 Aug 2019 00:53:37 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=richard.dapoigny AT univ-smb.fr; spf=Pass smtp.mailfrom=richard.dapoigny AT univ-smb.fr; spf=None smtp.helo=postmaster AT smtpout02-ext2.partage.renater.fr
Dear Coq users, Assuming classical logic with the following definitions: Variable object : Set. (* elements *) Is there a way to transform the following definition with Prop in classical logic (i.e., to remove booleans since left and right refer to sumbool): Definition Singleton (a:object) :=Caract (fun a':object => match eqobject_dec a a' with | left h => True | right h => False end). Thanks for your help. |
- [Coq-Club] Singleton with sets as characteristic functions in classical logic, richard dapoigny, 08/27/2019
- Re: [Coq-Club] Singleton with sets as characteristic functions in classical logic, Daniel Schepler, 08/27/2019
- Re: [Coq-Club] Singleton with sets as characteristic functions in classical logic, richard dapoigny, 08/27/2019
- Re: [Coq-Club] Singleton with sets as characteristic functions in classical logic, Christian Doczkal, 08/27/2019
- Message not available
- Re: [Coq-Club] Singleton with sets as characteristic functions in classical logic, richard dapoigny, 08/29/2019
