Re: [Coq-Club] Singleton with sets as characteristic functions in classical logic
- From: richard dapoigny <richard.dapoigny AT univ-smb.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Singleton with sets as characteristic functions in classical logic
- Date: Thu, 29 Aug 2019 23:43:56 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=richard.dapoigny AT univ-smb.fr; spf=Pass smtp.mailfrom=richard.dapoigny AT univ-smb.fr; spf=None smtp.helo=postmaster AT smtpout02-ext2.partage.renater.fr
Hi,
Le 29/08/2019 à 20:00, Christian Doczkal a écrit :
Hiwe import the classical logic (Classical_Prop, PropExtensionality and ClassicalEpsilon)
Merci Christian, mais notre objectif est de spécifier une théorie pourWait, are you saying you want to combine:
laquelle nous avons absolument besoin d'utiliser les fonctions
caractéristiques des ensembles. Cette contrainte forte nous empêche
d'envisager d'autres options.
1. No classical axioms other than (some instances of) XM
2. In particular, no boolean equality test on [object], i.e., onlycharacteristic functions in the classical framework become: object -> Prop
[forall a b, a = b \/ a <> b]
3. Sets as characteristic functions [object -> bool]
other definitions become classically:
Inductive N : Type := Caract : (object -> Prop) -> N.
Definition caract (s :N)(a:object) : Prop := let (f) := s in f a.
Definition In (s :N)(a:object) : Prop := caract s a = True.
Definition incl (s1 s2 :N) := forall a:object, In s1 a -> In s2 a.
Definition set_eq (s1 s2 :N) := forall a:object, In s1 a = In s2 a.
All the best,
Richard
4. A singleton operator.
This is clearly impossible since assuming a singleton operator (together with
the inherent decidable membership) immediately gives you a boolean equality
on [object]. Am I missing something here?
If you don't have a boolean equality on objects, I suppose using "characteristic
functions" of type [object -> Prop] (with Singleton a := eq a) looks more promising. This is
equivalent to the "Ensembles" in the standard library, whose use I would not recommend.
Best,
Christian
PS. I don't know whether taking the discussion off coq-club was intentional
or not. In any event, replying from a French address does not make me French.
- [Coq-Club] Singleton with sets as characteristic functions in classical logic, richard dapoigny, 08/27/2019
- Re: [Coq-Club] Singleton with sets as characteristic functions in classical logic, Daniel Schepler, 08/27/2019
- Re: [Coq-Club] Singleton with sets as characteristic functions in classical logic, richard dapoigny, 08/27/2019
- Re: [Coq-Club] Singleton with sets as characteristic functions in classical logic, Christian Doczkal, 08/27/2019
- Message not available
- Re: [Coq-Club] Singleton with sets as characteristic functions in classical logic, richard dapoigny, 08/29/2019
