coq-club - Re: [Coq-Club] Debugging an apparently diverging Coq program
  • From: Sylvain Boulmé <Sylvain.Boulme AT univ-grenoble-alpes.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Debugging an apparently diverging Coq program
  • Date: Mon, 23 Sep 2019 19:10:36 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=Pass smtp.mailfrom=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=None smtp.helo=postmaster AT zm-mta-out-1.u-ga.fr
By the way, a more sound implementation of the "fresh" axiom could be given the following Coq directives:
Extract Inductive list => "list" [ "[]" "(::)" ].
Extract Constant fresh => "fun l -> 1+(List.fold_left max 0 l)".
Le 23/09/2019 à 18:03, Sylvain Boulmé a écrit :
Hello,
Yes, I suspect that there is a lot of noise due to dependent types involved in proving the termination of Subst (and maybe some opaque constant on the way).
Hence extracting to OCaml is a good idea: on these examples, the computations are instantaneous!
I have rewritten the last 2 lines of the Coq files into:
Definition subst1 := Subst X (eUni) (eId X) (FV eUni).
Compute subst1.
Definition subst2 := Subst X (eUni) (eAbs Y (eUni) (eId X)) empty.
(* Timeout 300 Compute subst2. *)
Definition subst3 := Subst X (eUni) (eAbs Y (eUni) (eId Y)) empty.
Extract Constant atom => "int".
Extract Constant atomeq_dec => "fun x y -> if x=y then Left else Right".
  "let c = ref 0 in fun _ -> let n = !c in c:=n+1;n".
Extraction "subst.ml" subst1 subst2 subst3.
Then, in the "ocaml" toplevel, I write the directive:
#use "subst.ml";;
And, I get the following output:
val subst1 : cCexp = EUni
val subst2 : cCexp = EAbs (2, EUni, EUni)
val subst3 : cCexp = EAbs (3, EUni, EId 3)
Regards,
Sylvain.
Le 23/09/2019 à 17:05, Jason -Zhong Sheng- Hu a écrit :
have you tried to extract to ocaml or haskell to reduce noise from Prop?
*Thanks,*
*Jason Hu*
*https://hustmphrrr.github.io/*
*From:* coq-club-request AT inria.fr <coq-club-request AT inria.fr> on behalf of William J. Bowman <wilbowma AT ccs.neu.edu>
*Sent:* September 20, 2019 8:46 PM
*To:*
<coq-club AT inria.fr>
*Subject:* Re: [Coq-Club] Debugging an apparently diverging Coq program
I don’t think that’s the problem. Another model does get stuck on that equality and returns the if statement waiting for an interpretation of “==“. I didn’t expect Program to be efficient, but I do expect it to terminate quickly on this example, without using 20 GB of memory.
I’ll see if I can reduce the other model to something as small.
Sent from my phoneamajig
On Sep 20, 2019, at 17:35, Abhishek Anand <abhishek.anand.iitg AT gmail.com <mailto:abhishek.anand.iitg AT gmail.com>> wrote:
Perhaps they forgot to instantiate the atom type?  the computation would get stuck on (x == x'). `Program` often produces humongous functions.
-- Abhishek
http://www.cs.cornell.edu/~aa755/
On Fri, Sep 20, 2019 at 5:15 PM William J. Bowman <wjb AT williamjbowman.com <mailto:wjb AT williamjbowman.com>> wrote:
    All,
    At the following URL is a model of a language with
    capture-avoiding substitution
    that a student wrote:
    https://gist.github.com/wilbowma/acf125222c64ff715a33b26a0ce8b4ab
    The program looks (to me) like it ought to terminate quickly, and
    it's proven
    terminating using Program, yet when we run the substitution
    function on a small
    example... coqtop eats about 20 GB of memory and doesn't terminate
    within 5
    minutes.
    I'm using Coq 8.9.1 on MacOS 10.14.2; the same behavior is also
    observed on
    Windows 10.
    I'd appreciate any help debugging this.
    William J. Bowman
