- From: Xavier Leroy <xavier.leroy AT college-de-france.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Debugging an apparently diverging Coq program
- Date: Mon, 23 Sep 2019 19:36:54 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=xavier.leroy AT college-de-france.fr; spf=Pass smtp.mailfrom=xavier.leroy AT college-de-france.fr; spf=None smtp.helo=postmaster AT smtpout01-ext1.partage.renater.fr
On Mon, Sep 23, 2019 at 7:19 PM Jason -Zhong Sheng- Hu <fdhzs2010 AT hotmail.com> wrote:
have you tried to extract to ocaml or haskell to reduce noise from Prop?
"Program Fixpoint" produces terms that don't play well with extraction: https://github.com/coq/coq/issues/10757
The problem could come from accessibility proofs that don't compute. The following trick can help: https://sympa.inria.fr/sympa/arc/coq-club/2013-09/msg00034.html
- Xavier Leroy
From: coq-club-request AT inria.fr <coq-club-request AT inria.fr> on behalf of William J. Bowman <wilbowma AT ccs.neu.edu>
Sent: September 20, 2019 8:46 PM
To: coq-club AT inria.fr <coq-club AT inria.fr>
Subject: Re: [Coq-Club] Debugging an apparently diverging Coq programI don’t think that’s the problem. Another model does get stuck on that equality and returns the if statement waiting for an interpretation of “==“. I didn’t expect Program to be efficient, but I do expect it to terminate quickly on this example, without using 20 GB of memory.
I’ll see if I can reduce the other model to something as small.
--Sent from my phoneamajigPerhaps they forgot to instantiate the atom type? the computation would get stuck on (x == x'). `Program` often produces humongous functions.
On Fri, Sep 20, 2019 at 5:15 PM William J. Bowman <wjb AT williamjbowman.com> wrote:
All,
At the following URL is a model of a language with capture-avoiding substitution
that a student wrote:
https://gist.github.com/wilbowma/acf125222c64ff715a33b26a0ce8b4ab
The program looks (to me) like it ought to terminate quickly, and it's proven
terminating using Program, yet when we run the substitution function on a small
example... coqtop eats about 20 GB of memory and doesn't terminate within 5
minutes.
I'm using Coq 8.9.1 on MacOS 10.14.2; the same behavior is also observed on
Windows 10.
I'd appreciate any help debugging this.
William J. Bowman
- [Coq-Club] Debugging an apparently diverging Coq program, William J. Bowman, 09/21/2019
- Re: [Coq-Club] Debugging an apparently diverging Coq program, Abhishek Anand, 09/21/2019
- Re: [Coq-Club] Debugging an apparently diverging Coq program, Nathaniel Yazdani, 09/21/2019
- Re: [Coq-Club] Debugging an apparently diverging Coq program, William J. Bowman, 09/21/2019
- Re: [Coq-Club] Debugging an apparently diverging Coq program, Jason -Zhong Sheng- Hu, 09/23/2019
- Re: [Coq-Club] Debugging an apparently diverging Coq program, Sylvain Boulmé, 09/23/2019
- Re: [Coq-Club] Debugging an apparently diverging Coq program, Xavier Leroy, 09/23/2019
- Re: [Coq-Club] Debugging an apparently diverging Coq program, William J. Bowman, 09/23/2019
- Re: [Coq-Club] Debugging an apparently diverging Coq program, Pierre Courtieu, 09/24/2019
- Re: [Coq-Club] Debugging an apparently diverging Coq program, Jason -Zhong Sheng- Hu, 09/21/2019
- Re: [Coq-Club] Debugging an apparently diverging Coq program, Xuanrui Qi, 09/21/2019
- Re: [Coq-Club] Debugging an apparently diverging Coq program, Théo Winterhalter, 09/21/2019
- Re: [Coq-Club] Debugging an apparently diverging Coq program, Gaëtan Gilbert, 09/21/2019
