coq-club - Re: [Coq-Club] Why does coq_makefile impose -q option?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Why does coq_makefile impose -q option?
  • Date: Fri, 25 Oct 2019 22:18:55 -0700
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=itz AT very.loosely.org; spf=Pass smtp.mailfrom=itz AT very.loosely.org; spf=Pass smtp.helo=postmaster AT very.loosely.org
  • Ironport-phdr: 9a23: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
On 2019-10-12 22:58, Gaëtan Gilbert wrote:
> > So ... -init-file is getting passed correctly, but it has no effect
> > because it is accompanied by -q. Why does coq_makefile pass -q to
> > coqc, and how can I change this behavior?
> make COQFLAGS=
Thanks, I didn't use this literally but it showed me the way.
But now, how to make this work in coqide? Nothing I tried so far worked
- usually coqide refuses to even start, saying "coqidetop stopped badly"
or something like that. If I don't do anything it starts OK but it
won't parse any file that contains ssreflect notations.
This is the same with coqide 8.9 (Gtk 2 based) and 8.10 (Gtk 3 based).
Everything works if I put those imports in my _global_ ~/.coqrc but I
don't want to do that - among other reasons because then at least one
opam package fails to build, not isolating itself from the local
configuration.
Please don't Cc: me privately on mailing lists and Usenet,
if you also post the followup to the list or newsgroup.
To reply privately _only_ on Usenet and on broken lists
which rewrite From, fetch the TXT record for no-use.mooo.com.
