coq-club - Re: [Coq-Club] Why does coq_makefile impose -q option?
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Why does coq_makefile impose -q option?
  • Date: Sat, 26 Oct 2019 15:58:55 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-ed1-f45.google.com
  • Ironport-phdr: 9a23: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
My guess is that it's a historical accident.  I suspect `coqc` started out as a thin wrapper for `coqtop -compile` (though I am by no means confident about this), and inherited the default options.
On Sat, Oct 26, 2019 at 1:27 PM Ian Zimmerman <itz AT very.loosely.org> wrote:
On 2019-10-26 02:30, Jason Gross wrote:
> I believe .coqrc is intended for local commands that you might want for
> interactive use, but not globally.  e.g., you might have a different
> preferred printing width (Set Printing Width) or depth (Set Printing
> Depth).
This sounds sensible, but why does coqc also obey the commands in this
file, in such case?
Please don't Cc: me privately on mailing lists and Usenet,
if you also post the followup to the list or newsgroup.
To reply privately _only_ on Usenet and on broken lists
which rewrite From, fetch the TXT record for no-use.mooo.com.
