coq-club - [Coq-Club] rewriting in an equality without eq_ind_r / transport
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] rewriting in an equality without eq_ind_r / transport
  • Date: Mon, 11 Nov 2019 19:02:53 -0500
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=Neutral smtp.pra=jdc AT uwo.ca; spf=None smtp.mailfrom=gsmlcc-coq-club AT m.gmane.org; spf=None smtp.helo=postmaster AT blaine.gmane.org
  • Cancel-lock: sha1:Bogk24HFtq2SSA83dfUAjF3jef4=
  • Ironport-phdr: 9a23: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
  • Mail-copies-to: never
The tactic
rewrite lem
does two clever things. It figures out arguments to pass to the
function lem so that it produces an equality whose left-hand-side
matches a sub-term of the goal, and it abstracts away that sub-term
to make the goal into a type family.
However, in the case where the goal is an equality, it produces proof
terms that are more complicated than necessary. (I'm working within
the HoTT library, where I need to manipulate the proof terms later in
the development.)
Below I give a simplified example of two proofs of the same theorem,
one using rewrite (which generates a proof term using eq_ind_r) and
one using f_equal and eq_trans. (In HoTT lingo, those would be
internal_paths_rew_r, and ap and concat, respectively.)
I would like a tactic that is as easy to use as rewrite but which
produces proofs like the second method below.
I came up with a crude tactic rewrite_in_lhs that often works, also
shown below. In this example, it works perfectly. However, in more
complicated examples, the line
let f := constr:(fun w : T => ltac:(let t := context F [w] in exact t)) in
generates an Ltac error when the lambda expression is not well-typed,
and Coq doesn't backtrack and try a different match. (The same problem
happens if I try using "eval pattern src in lhs".)
So my question is whether there is a more robust way to match a lemma
to a sub-term and then abstract the context of the sub-term to a
function, which I can then manipulate further.
If an Ltac error can be caught and converted into a tactic failure,
that would work. But even if that is possible, my method is much
slower than rewrite, so I hope that there is a more direct solution.
Thanks for any help!
Dan
Parameter A C : Type.
Parameter g : A -> C.
Parameter c : C.
Axiom lem : forall a : A, g a = c.
Theorem example {B : Type} (f : C -> B) (a : A) (b : B) (q : f c = b)
: f (g a) = b.
Proof.
rewrite lem. (* [lem a] gives [g a = c] *)
exact q.
Qed.
Print example.
(* fun (B : Type) (f : C -> B) (a : A) (b : B) (q : f c = b) =>
eq_ind_r (fun c : C => f c = b) q (lem a) *)
Theorem example' {B : Type} (f : C -> B) (a : A) (b : B) (q : f c = b)
: f (g a) = b.
Proof.
exact (eq_trans (f_equal f (lem a)) q).
Qed.
Print example'.
eq_trans (f_equal f (lem a)) q *)
(* Try *every* subterm [t] of lhs to see if [lem] can give a path [p]
starting at [t].
If so, do [refine (eq_trans (f_equal f p) _)] for suitable [f]. *)
Tactic Notation "rewrite_in_lhs" uconstr(lem) :=
lazymatch goal with
| |- ?lhs = ?rhs
=> match lhs with
| context F [?src]
=> let T := type of src in
t)) in
refine (eq_trans (f_equal f _) _); [eapply lem | idtac]
end
end.
Lemma example'' {B : Type} (f : C -> B) (a : A) (b : B) (q : f c = b)
: f (g a) = b.
Proof.
rewrite_in_lhs lem.
exact q.
Qed.
Print example''.
eq_trans (f_equal (fun w : C => f w) (lem a)) q *)
