- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] rewriting in an equality without eq_ind_r / transport
- Date: Wed, 13 Nov 2019 12:14:22 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=Neutral smtp.pra=jdc AT uwo.ca; spf=None smtp.mailfrom=gsmlcc-coq-club AT m.gmane.org; spf=None smtp.helo=postmaster AT blaine.gmane.org
- Cancel-lock: sha1:enIIzjam0t8mDEeh6StWXGhOd8U=
- Ironport-phdr: 9a23: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
- Mail-copies-to: never
On Nov 12, 2019, Clément Pit-Claudel
<cpitclaudel AT gmail.com>
wrote:
> `set` is a bit more powerful that context[] pattern-matching.
Thanks for explaining!
> What you need to make your example go through is
> match goal with
> | [ |- context[?x] ] =>
> unify x source;
> … but in general, I'd stay away from evar-based strategies.
Right, I tried unify after sending my last message, and it doesn't work
well. For example, the term 4 * (m + (3 * n) *does* unify against
?x + ?y, since it expands to a sum. But I don't want to rewrite
something that isn't explicitly written as a sum. So unify is out.
> Consider this instead:
> Ltac source thm :=
> let tau := type of thm in
> lazymatch tau with
> | forall x: ?t, _ =>
> constr:(fun x: t =>
> ltac:(let thm' := constr:(thm x) in
> let thm'' := (eval cbv beta in thm') in
> let src := source thm'' in
> exact src))
> | ?src = _ => constr:(src)
> end.
That's a nice way to avoid having to know the number of arguments that
the lemma takes. There are still two other places where I need to list
the arguments, which I've pulled out into another helper function.
Ltac find_function fn term :=
match term with
| context[fn ?a1 ?a2 ?a3] => constr:(fn a1 a2 a3)
| context[fn ?a1 ?a2 ] => constr:(fn a1 a2)
| context[fn ?a1 ] => constr:(fn a1)
| context[fn ] => constr:(fn)
end.
I was hoping to be able to use the "as ident" form to avoid repeating
myself, e.g.
match term with
| context[fn ?a1 ?a2 ?a3 as W],
context[fn ?a1 ?a2 as W] => constr:(W)
(and more cases) but it doesn't work within a context search. Any
ideas?
With those two helper functions, my tactic is now:
Tactic Notation "rewrite_in_lhs" uconstr(lem) :=
let f := source lem in
let fn := fresh "f" in
set f as fn;
lazymatch goal with
| |- ?lhs = ?rhs =>
let fnargs := find_function fn lhs in
let P := eval pattern fnargs in lhs in
match P with
| ?F ?w =>
refine (eq_trans (f_equal F _) _); [eapply lem | ]
end
end;
subst fn.
And it works!
Goal forall m n, (4 * (m + (3 * n)) * 2) = 1.
intros.
rewrite_in_lhs' Nat.add_comm.
Abort.
There are still some issues, though:
1) I found an edge case where the set method doesn't work. Sometimes
the type of the equality is forall a : A, a = foo a. Then the source of
this is the identity function, and set does not insert the identity
function into the goal, so the match fails. Here's an example:
Axiom Pt : Type.
Axiom c0 : Pt.
Axiom alleq : forall c : Pt, c = c0.
Goal forall c c' : Pt, c = c'.
intros.
Fail let f := source alleq in
set f as fn;
match goal with [ |- context[fn ?x] ] => idtac end.
rewrite alleq at 1. (* Succeeds. *)
Abort.
Any ideas?
2) I want to work with one side of the equation at a time, but
the "set f as fn" applies to the whole goal. Is there a way to
do that substitution just in the lhs? Not only would it be more
efficient, it would avoid changing the rhs:
Goal forall m n, (4 * (m + (3 * n)) * 2) = m + n.
intros.
rewrite_in_lhs Nat.add_comm.
(* RHS changes to (fun n0 m0 : nat => n0 + m0) m n *)
Abort.
Thanks again!
Dan
- [Coq-Club] rewriting in an equality without eq_ind_r / transport, Dan Christensen, 11/12/2019
- Re: [Coq-Club] rewriting in an equality without eq_ind_r / transport, Samuel Gruetter, 11/12/2019
- Re: [Coq-Club] rewriting in an equality without eq_ind_r / transport, Dan Christensen, 11/12/2019
- Re: [Coq-Club] rewriting in an equality without eq_ind_r / transport, Talia Ringer, 11/12/2019
- Re: [Coq-Club] rewriting in an equality without eq_ind_r / transport, Clément Pit-Claudel, 11/12/2019
- Re: [Coq-Club] rewriting in an equality without eq_ind_r / transport, Dan Christensen, 11/13/2019
- Re: [Coq-Club] rewriting in an equality without eq_ind_r / transport, Clément Pit-Claudel, 11/13/2019
- Re: [Coq-Club] rewriting in an equality without eq_ind_r / transport, Dan Christensen, 11/14/2019
- Re: [Coq-Club] rewriting in an equality without eq_ind_r / transport, Jason Gross, 11/14/2019
- Re: [Coq-Club] rewriting in an equality without eq_ind_r / transport, Dan Christensen, 11/15/2019
- Re: [Coq-Club] rewriting in an equality without eq_ind_r / transport, Gaëtan Gilbert, 11/15/2019
- Re: [Coq-Club] rewriting in an equality without eq_ind_r / transport, Samuel Gruetter, 11/16/2019
- Re: [Coq-Club] rewriting in an equality without eq_ind_r / transport, Dan Christensen, 11/16/2019
