coq-club - Re: [Coq-Club] Fwd: coqdoc autoinsert query results
  • To: Coq Club <coq-club AT inria.fr>
  • Cc: abhishek.anand.iitg AT gmail.com
  • Subject: Re: [Coq-Club] Fwd: coqdoc autoinsert query results
  • Date: Wed, 4 Mar 2020 22:57:45 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=theo.zimmi AT gmail.com; spf=Pass smtp.mailfrom=theo.zimmi AT gmail.com; spf=None smtp.helo=postmaster AT mail-ua1-f45.google.com
  • Ironport-phdr: 9a23:7FIa1RQoHxTFEcHBfXTgho4OONpsv+yvbD5Q0YIujvd0So/mwa67bRaN2/xhgRfzUJnB7Loc0qyN7PCmBDRIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnY6Uy/yPgttJ+nzBpWaz4Huj7jzqNXvZFBjgyP1SrdvJl3ipgLI88ISnIFKK6AryxKPrGEeKMpMwmY9GVISmCHO58K18YRm+iJW86Y998NHF7f7eqE5ZbNdBTUidWsy4Zu45lH4UQKT6y5EAS0tmR1SDl2AtUmiB8ujgm7BruN4nRKiE4juV7ltAGat6q5qTFnjjyJVb2dkolGSsdR5iedgmDzkpxF7xNSJMoScNf47Y6qEON1GGCxOWcFeUyEHCYS5PdNWXrgxeN1Apoy4nGMg6B63BA2iHuTqk2YaiXr/3Kl82OMkQ1jL
Hi Abhishek,
Feel free to open an issue to further discuss your issue. There have been talks of making the tool that Jim mentioned more generally available/usable for use cases beyond the Coq reference manual.
Théo
Le mer. 4 mars 2020 à 22:19, Jim Fehrle <jim.fehrle AT gmail.com> a écrit :
There is such a feature for processing the examples that appear in the documentation, part of our Sphinx customization.  For example:
.. coqtop:: reset none
   Parameters (A : Prop) (B: nat -> Prop) (C: Prop).
.. coqtop:: out
   Goal A /\ (exists x:nat, B x /\ C) -> True.
.. coqtop:: all
   intros (a & x & b & c).
"none", "in", "out" control whether to display the input and output.
Perhaps some of this could be adapted for your use case.  No idea how much work that would require.
Jim
On Wed, Mar 4, 2020 at 12:56 PM Abhishek Anand <abhishek.anand.iitg AT gmail.com> wrote:
Is there a way in coqdoc or a similar tool to automatically include query results in the generated document, especially HTML document?
For example, if I have the following source file,
Check Nat.add_0_l.
the HTML output should be:
Check Nat.add_0_l.
Nat.add_0_l
     : ∀ n : nat, 0 + n = n
If coqdoc can't do this, some sort of a .v file preprocessor could use coqtop to convert
Check Nat.add_0_l.
 into
Check Nat.add_0_l.
Nat.add_0_l
before invoking coqdoc?
