coq-club - [Coq-Club] coqdoc autoinsert query results
  • From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] coqdoc autoinsert query results
  • Date: Wed, 4 Mar 2020 12:54:23 -0800
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-il1-f195.google.com
  • Ironport-phdr: 9a23:wOvUrxA+xnrF90sYgiUpUyQJP3N1i/DPJgcQr6AfoPdwSP38r8bcNUDSrc9gkEXOFd2Crakb26yL6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6i760TlHERLmcAFxO+69ToXVloG80/2405zVeQRBwjSnN+BcNhKz+CzbtsgNgYZhYo83wx3F6i9BceRX3mNlJhSamR/66oGx/YJs2ytVsvMlscVHVPOpLOwDUbVEAWF+YCgO78rxuEybFFfd1j4nSmwT1yFwLU3d9hijB8X+tyL7sqx23yzIZZSnH4BxYiyr6uJQcDGtjS4GMzAj92SO055/iatapFSqoBktmteJMrHQD+J3e+bmRf1fRWdFWZwPBSlIA4f5bo9WSuRYbLseoI76qF8D6xC5AFv0CQ==
Is there a way in coqdoc or a similar tool to automatically include query results in the generated document, especially HTML document?
For example, if I have the following source file,
Check Nat.add_0_l.
the HTML output should be:
Check Nat.add_0_l.
Nat.add_0_l
     : ∀ n : nat, 0 + n = n
If coqdoc can't do this, some sort of a .v file preprocessor could use coqtop to convert
Check Nat.add_0_l.
 into
Check Nat.add_0_l.
Nat.add_0_l
before invoking coqdoc?
