- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Fwd: Hiding "Obvious" Hypothesis?
- Date: Thu, 2 Apr 2020 02:44:50 +0000
- Accept-language: en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gruetter AT mit.edu; spf=Pass smtp.mailfrom=gruetter AT mit.edu; spf=None smtp.helo=postmaster AT outgoing-exchange-5.mit.edu
- Ironport-phdr: 9a23:dxOKOhU1vuvTGug2cPH0gqG93RbV8LGtZVwlr6E/grcLSJyIuqrYZROAt8tkgFKBZ4jH8fUM07OQ6P+wHzFYqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aSV3DMl8/LePsX4XWks6f1uao+pSVbR8CzG62Zqo3JxGrpy3QsNMXiM1sMPBi5AHOpy5zcuFLyGcgCkiOkgrg6934qJF57ilMp/8738tBTeP3c7luHu8QNygvL21gvJ6jjhLEVwbaviJNAFVTqQJBBk3+1D+/W57wtiXgse8siiybIYv7Qa1mAG3+vZcucwfhjWI8DxB86Hve2551jb4drR689UQmntzkJbqNPf87RZvzONMXQW0bD5RWSjBOBYK6YM4CH+EBNOBXosyg4V4PsV2zCRT+XO4=
Here's solution which does not exactly hide them, but at least puts everything you want to ignore into one place:
Require Import Coq.Lists.List. Import ListNotations.
Inductive IgnoreAboveThisLine := mkIgnoreAboveThisLine.
Notation "'_______________________'" := IgnoreAboveThisLine.
Goal forall
(l1 l2: list nat)
(H0: l1 = l2 ++ l2)
(bs1: list bool)
(x: nat)
(bs2: list bool)
(H1: true :: bs1 = bs2 ++ bs1)
(y: nat)
(H2: x :: l1 = y :: y :: l2),
l1 ++ l2 ++ l1 = (l1 ++ l2) ++ l1.
Proof.
intros.
(* 8 lines of hypotheses, variables and hypotheses mixed:
l1, l2 : list nat
H0 : l1 = l2 ++ l2
bs1 : list bool
x : nat
bs2 : list bool
H1 : true :: bs1 = bs2 ++ bs1
y : nat
H2 : x :: l1 = y :: y :: l2
repeat match goal with
| x: ?T |- _ =>
match type of T with
| Prop => revert x
end
end.
pose proof mkIgnoreAboveThisLine as __.
| x: ?T |- _ =>
| y: T |- _ => revert y
end
end.
intros.
(* All the hypotheses you're interested in are below the single dashed line,
and the variables are sorted by type to save lines:
l1, l2 : list nat
bs1, bs2 : list bool
x, y : nat
__ : _______________________
H0 : l1 = l2 ++ l2
And since proof general scrolls to the bottom of your goal by default, the variables you're not interested in are the first lines which are going to be hidden if you run out of space.
On Wed, 2020-04-01 at 16:58 -0500, Agnishom Chattopadhyay wrote:
---------- Forwarded message ---------
From: Agnishom Chattopadhyay <agnishom AT cmi.ac.in>
Date: Wed, Apr 1, 2020 at 4:54 PM
Subject: Hiding "Obvious" Hypothesis?
To: <coq-club AT inria.fr>
Hi;
Very often, I end up with a proof environment which looks like this:
buf : list bool
sc : list bool -> bool
cnt : nat
l2, l1 : list A
H : length l1 > 0
Hx : length l2 > 0
b2 : list bool
m2 : Monitor A
H0 : eval4 m (l2 ++ l1) = (b2, m2)
b2' : bool
m2' : Monitor A
bs2' : list bool
H11 : (bs2', m2') = eval4 (monExpandSlider m buf sc cnt) (l2 ++ l1)
H12 : b2' = hd false bs2'
H2 : length l1 = cnt
H1' : eval2 (monExpandSlider m buf sc cnt) (l2 ++ l1) = (b2', m2')
bs1' : list bool
m1' : Monitor A
E : eval4 (monExpandSlider m buf sc cnt) l1 = (bs1', m1')
bb2' : list bool
F : eval4 m1' l2 = (bb2', m2')
H4 : bs2' = bb2' ++ bs1'
bs1 : list bool
m1 : Monitor A
G : eval4 m l1 = (bs1, m1)
b1 : bool
mm1 : Monitor A
E11 : (b1, m1') = eval2 (monExpandSlider m buf sc cnt) l1
E12 : b1 = hd false bs1'
buf1 : list bool
B11 : buf1 = bs1 ++ buf
B12 : m1' = monSlider m1 buf1 sc
B13 : b1 = sc buf1
bb2 : list bool
I : eval4 m1 l2 = (bb2, m2)
H5 : b2 = bb2 ++ bs1
bx2' : bool
F1 : (bx2', m2') = eval2 (monSlider m1 buf1 sc) l2
F2 : bx2' = hd false bb2'
H1 : length buf1 > 0
buf2 : list bool
H31 : buf2 = firstn (cnt + length buf) ((bb2 ++ bs1) ++ buf)
H32 : m2' = monSlider m2 buf2 sc
H33 : length buf2 = cnt + length buf
H34 : b2' = sc buf2
H6 : length buf1 = cnt + length buf
H7 : bx2' = b2'
exists buf0 : list bool,
buf0 = firstn (cnt + length buf) ((bb2 ++ bs1) ++ buf) /\
m2' = monSlider m2 buf0 sc /\ length buf0 = cnt + length buf /\ b2' = sc buf0
There is a lot of Hypotheses here, but more than half of these are obvious to the Human user. For example, the type of buf, sc, cnt, l2, l1, b2, b2' and so on are clear to me. Is there a proof general mode or a plugin or a tactic that gives a way to hide these hypotheses?
I suppose one way of classifying such hypotheses would be to look at all the hypotheses whose type is not of kind Prop
--Agnishom
- [Coq-Club] Fwd: Hiding "Obvious" Hypothesis?, Agnishom Chattopadhyay, 04/01/2020
- Re: [Coq-Club] Fwd: Hiding "Obvious" Hypothesis?, Samuel Gruetter, 04/02/2020
- Re: [Coq-Club] Fwd: Hiding "Obvious" Hypothesis?, Pierre Courtieu, 04/02/2020
- Re: [Coq-Club] Fwd: Hiding "Obvious" Hypothesis?, jonikelee AT gmail.com, 04/02/2020
- Re: [Coq-Club] Fwd: Hiding "Obvious" Hypothesis?, jonikelee AT gmail.com, 04/03/2020
- Re: [Coq-Club] Fwd: Hiding "Obvious" Hypothesis?, Paolo Giarrusso, 04/09/2020
- Re: [Coq-Club] Fwd: Hiding "Obvious" Hypothesis?, Agnishom Chattopadhyay, 04/10/2020
- Re: [Coq-Club] Fwd: Hiding "Obvious" Hypothesis?, Paolo Giarrusso, 04/10/2020
