coq-club - Re: [Coq-Club] Fwd: Hiding "Obvious" Hypothesis?
  • From: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Fwd: Hiding "Obvious" Hypothesis?
  • Date: Thu, 2 Apr 2020 22:29:57 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=pierre.courtieu AT gmail.com; spf=Pass smtp.mailfrom=pierre.courtieu AT gmail.com; spf=None smtp.helo=postmaster AT mail-il1-f175.google.com
  • Ironport-phdr: 9a23:YqQpYhzFTj8TXijXCy+O+j09IxM/srCxBDY+r6Qd0uwSIJqq85mqBkHD//Il1AaPBtqLra8cw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2NBXupSi56idXERHiPyJ0IP70E8jclZeZzee3rqXSbh9SiXKWZq5oMBS7sE2Frsgbm5FvbK021wHVo3ZVU+tTzGJsY1mUmkCvtY+L4Jd//nEI6Loa/MlaXPCiJvlqffljFD0jdlsNyojruB3EF1Xd43IdViAXlkMNDVGasVf1WZD+tia8ve14inHDbJ/GCIssUDHn1J9FDRrhiSMJLTk8qTiFhcl5jaYdqxWk9UUmn9zkJbqNPf87RZvzOMsATDMYDMlUXi1FRIi7atlXAg==
Hi Jonathan
Nice!
P
Le jeu. 2 avr. 2020 à 19:14, jonikelee AT gmail.com <jonikelee AT gmail.com> a écrit :
On Thu, 2 Apr 2020 11:55:51 -0400
"jonikelee AT gmail.com" <jonikelee AT gmail.com> wrote:
> On Thu, 2 Apr 2020 11:23:31 -0400
> > On Thu, 2 Apr 2020 10:45:49 +0200
> > Pierre Courtieu <Pierre.Courtieu AT cnam.fr> wrote:
> > > Nice ltac!
> > > I have something similar in LibHyps without touching the proof
> > > term (thanks to ltac hack from J.Leivant).
> > Here's the source for that hypothesis harvesting and iteration hack:
> > https://github.com/jonleivent/mindless-coding-phase2/blob/master/hypiter.v
> Somewhere, I had a version of this hack that grouped like-typed
> hypotheses together to take full advantage of ProofGeneral's ability
> to list adjacent like-typed hypotheses on the same line.  I'll look
> for it...
This 'minlines' tactic is it, from:
https://github.com/jonleivent/mindless-coding-phase2/blob/master/utils.v
Ltac revert_all :=
  repeat lazymatch goal with H:_ |- _ => revert H end.
Ltac get_value H := eval cbv delta [H] in H.
Ltac has_value H := let X:=get_value H in idtac.
Ltac minlines :=
  idtac; (*prevent early eval*)
  let stop:=fresh "stop" in
  generalize I as stop;
  revert_all;
  let rec f :=
    try (intro;
         lazymatch goal with H:?T |- _ =>
          first[constr_eq H stop; clear stop
               |let v := get_value H in
                try match goal with H' := v : T |- _ =>
                 first[constr_eq H H'; fail 1
                      |move H before H'] end; f
               |try match goal with H':T |- _ =>
                      |has_value H'; fail 1
               |f]
          end)
  in f.
What this does to the goal in Pierre's example in ProofGeneral:  After
the 'onAllHyps move_up_types' tactic, the goal is:
1 subgoal (ID 63)
  y : nat
  bs2 : list bool
  x : nat
  bs1 : list bool
  l2, l1 : list nat
  H0 : l1 = l2 ++ l2
  H1 : true :: bs1 = bs2 ++ bs1
  H2 : x :: l1 = y :: y :: l2
  l1 ++ l2 ++ l1 = (l1 ++ l2) ++ l1
If you then execute 'minlines', the goal becomes:
1 subgoal (ID 96)
  y, x : nat
  bs2, bs1 : list bool
  l2, l1 : list nat
  H0 : l1 = l2 ++ l2
They are usable separately or together.  I think minlines is idempotent.
I have found minlines particularly useful in goals which have many
hypotheses of simple types (consider a goal with 20 nats scattered
about) and only a few with complex types important to furthering the
proof.
-- Jonathan
