coq-club - [Coq-Club] Problem with large existential
  • To: <coq-club AT inria.fr>
  • Subject: [Coq-Club] Problem with large existential
  • Date: Thu, 2 Apr 2020 13:54:57 -0500
  • Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass (sender ip is 129.237.207.24) smtp.rcpttodomain=inria.fr smtp.mailfrom=ku.edu; dmarc=bestguesspass action=none header.from=ku.edu; dkim=none (message not signed); arc=none
  • Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=qEP6Gx+fFOv9giOAPW5ohIL8UW/FHB2BdEeLoJUfZMI=; b=ATskZzs1XJH0ATTs68d5tdd62zshcSWuURiEaTqlZfntiLo0+RP/f3+Y8+6var+yCCUhs6mLwG0HQVuRTL4jeGjG+dFzGTkQVsEGDCoj1cZQgE2LMGhrxQOPZ46PwiIV6X1SMLaOLGhJAzvoMXxRDyeBXtPNxRAB9GJHVHlXu5RicBB5bqIkgUP7RZrpKQgYuCcU7cCmiiGA+7NS6dEiLojPzog3qfv0mBXYbtMmwpDleqUkLghh3nCPhTHYkpi35nf64Be4UtxM3rB+/KovNlYV6E4VqN/W/DBHBWsweACxiKGClIcH4jFRe1Y/Urgt5eBKKTx7oT57St8yIoZXmA==
  • Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=WhSd0eXPecRjX8PirqheaIv5qAKWTFXjfLzV9QSo3TtBnO8aYl/V+4o8FAvgOGpKYSFJHSn+4WUl8tq89uZukg4uF8vvHWzyaNLsAwi7VzIkEShBHbVFuymNwBsCzV8G9vbKklhPW/dzQOGf2l74O+d2TXP12wGRtefi2gWRS35OGoAURouThloC2a60UT17mgZE56nZCM94/dZ9Qb53II0xamQK4eOxBaYXISEVGz1vV6vqaX8jQsNOz70bVfzvap6IaKq32ifJSKwB4PZpbCj1zWyN6KxL0dnE3Ur1ZicE6zwXWSPX22z2eY3y924xeFcqwLmt0YoMjUuw/DrNcA==
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=tjbarclay AT ku.edu; spf=Pass smtp.mailfrom=tjbarclay AT ku.edu; spf=Pass smtp.helo=postmaster AT NAM10-BN7-obe.outbound.protection.outlook.com
  • Ironport-phdr: 9a23:kfZTRh9hlpJFI/9uRHKM819IXTAuvvDOBiVQ1KB+1ugcTK2v8tzYMVDF4r011RmSAtWdtqoMotGVmp6jcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS46tL2HV9ym56idXERHiPyJ0IP70E8jclZLk+fq1/sjvYU1ijSC2ZbpjZEGqrw/YrMISiJpKKbt3xxfU9CgbM99KzH9lcArA1y334d29qcY6r3Zg/sk5/ssFap3UOrwiROwKDylgPmwotpWy6EvzCDCX735ZaV041xpFBw+Zs0Pcd7Ko6m7QkLU43yOXe8rrUbozRDKuqb9xTwPlgzsGMDh/93zLjst3j+RQpxfz/kUukb6RW5mcMb9FRo2YeNobQWRbWcMBBS9cRI6wctlWAg==
Howdy All,
I am currently running into some issues with large data structures causing Coq to break, and wonder if anyone's got any tips here.
I have a programming language with a relationally defined semantics. I'm trying to use an existential quantifier in order to "discover" the environment created by evaluating an _expression_ in the language.
For example I can write :
    exists (e : ENV), evalRel *initalEnv* *_expression_* *value* e
Then I can proceed to use tactics like econstructor to let the prover generate the proper value for e. This works for small expressions, but when given an entire program Coq eventually hangs while in the middle of proving. It seems like the large size of the value generated for the environment is causing problems. I've tried this inside Proof General, CoqIDE, and coqc, but all three eventually crash.
Thanks in advance,
TJ
TJ Barclay
Electrcial Engineering & Computer Science, University of Kansas
+1 316 259 2250
  • [Coq-Club] Problem with large existential, Tj Barclay, 04/02/2020
