- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Commands/Tools for Debugging Universe Inconsistency?
- Date: Fri, 10 Apr 2020 11:09:42 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=liyao AT seas.upenn.edu; spf=Pass smtp.mailfrom=liyao AT seas.upenn.edu; spf=None smtp.helo=postmaster AT mail-qt1-f177.google.com
- Ironport-phdr: 9a23:99WYrR8AJUx0l/9uRHKM819IXTAuvvDOBiVQ1KB+1uocTK2v8tzYMVDF4r011RmSAtWdtqoMotGVmp6jcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS46tL2HV93a19HsZHgj1HQtzPOX8XIDI3Oqt0OXnypTUKyFJzG65YKJ7Kz2toAzK8NQOjI1kbKs9102a8TNzZ+1KyDYwdhqolBHm65Lopc8xw2Fro/sksvV4f+D/dqU8Q6ZfCW14YXs47datqAHOSw3J63cBADxPz0h4RjPd5RS/Za/f9yv3su0nhnufNMzyCKkoAHGstvg0DhDvjygDOngy92SF0pUs3pIemwqoollE+6CReJucbaQsZa7UZpUHXWdHWIBcWzETWo4=
I see. That makes sense.
However, I am getting Foo.2 from a library. Any way to bind it to a stable
universe outside the library?
Another question is what are the cases that Coq >= 8.10 will automatically
name universes? When the codebase is large, naming many universes manually
would be painful...
Best,
Yao
> On Apr 10, 2020, at 10:57 AM, Gaëtan Gilbert
> <gaetan.gilbert AT skyskimmer.net>
> wrote:
> The Foo.number universes are unstable (for instance the number changes if
> you backtrack and rerun the command which generated the universe) so you
> can't put them into a script.
> Instead you have to ensure they get a name when created (so eg if you have
> Definition foo := Type. (* produces Type@{Foo.123} *)
> you can replace it by
> Universe foo_univ.
> Definition foo := Type@{foo_univ}.
> Coq >=8.10 will automatically name universes in some cases (for instance
> the above example actually uses the name "foo.u0" not "Foo.123").
> Gaëtan Gilbert
> On 10/04/2020 17:42, Yao Li wrote:
>> Hi Christian,
>> Thanks for the pointers! They are helpful. In particular, I find your
>> suggestion of using the “Constraint” command quite useful. I would like to
>> reiterate that suggestion here:
>>> - once one has located the spot where needlessly strong constraints
>>> (usually
>>> U = V for some U and V) are enforced, one can precede said
>>> lemma/definition
>>> with a "Contraint" command ruling out the equality (e.g., Contraint U <
>>> V) to
>>> force backtracking within the definition/lemma. Afterwards, the desired
>>> parallel structure can be reestablished.
>> However, I have universe variables whose names are in the form of “Foo.2”,
>> which cannot be parsed by Coq, even under “Constraint” command (Coq would
>> complain:"Error: Syntax Error: Lexer: Undefined token”). This prevents me
>> from putting any constraints regarding “Foo.2”. Is this a bug or did I
>> miss something?
>> Best,
>> Yao
>>> On Apr 10, 2020, at 3:30 AM, Christian Doczkal
>>> <christian.doczkal AT inria.fr
>>> <mailto:christian.doczkal AT inria.fr>>
>>> wrote:
>>> Hi,
>>> the subject has been discussed on this list before, and I am not aware
>>> of any tooling advances made since then. The two treads I have been
>>> involved in are:
>>> https://sympa.inria.fr/sympa/arc/coq-club/2018-09/msg00008.html
>>> https://sympa.inria.fr/sympa/arc/coq-club/2019-11/msg00087.html
>>> I hope this helps!
>>> Best,
>>> Christian
>>> On 4/10/20 1:14 AM, Yao Li wrote:
>>>> Dear All,
>>>> I am having some recurring universe inconsistency problems lately and I
>>>> would like to know if there are any commands/tools for helping me
>>>> debugging what happened.
>>>> For example, a recurring pattern is that Coq complains to me that it
>>>> cannot unify two universe levels (assuming they are u1 and u4) because
>>>> “u1 <= u2 < u3 <= u4” or “u1 <= u2 < u3 = u4”. I would like to know
>>>> where the constraints concerning u3 and u4 (and perhaps other relevant
>>>> constraints as well) are generated—or better yet, why. However, I
>>>> haven’t found a tool for doing that.
>>>> I have tried “Set Printing Universes”. Unfortunately, the constraints
>>>> concerning u3 and u4 cannot be found at any relevant definitions. I have
>>>> also tried “Print Universes”, but I cannot find what I’m looking for in
>>>> the sea of constraints that Coq shows me.
>>>> Best,
>>>> Yao
- [Coq-Club] Commands/Tools for Debugging Universe Inconsistency?, Yao Li, 04/10/2020
- Re: [Coq-Club] Commands/Tools for Debugging Universe Inconsistency?, Christian Doczkal, 04/10/2020
- Re: [Coq-Club] Commands/Tools for Debugging Universe Inconsistency?, Yao Li, 04/10/2020
- Re: [Coq-Club] Commands/Tools for Debugging Universe Inconsistency?, Gaëtan Gilbert, 04/10/2020
